Type "w-1013c" into the Store search field on vansaircraft.com, and you'll see the 4 related parts (2 left, 2 right).View attachment 59509
I have the pieces to assemble the Left side assembly, but did not receive the Right side versions of W-1013C-LX and W-1013C-R. Are they the same nomenclature and just reversible? Hesitant to order without the correct stock identifier. Thanks.
Yes. Thank you. I finally just looked for and found an outboard hinge assembly in a drawing in the next section which show the orientation for the left wing which cleared up my confusion as to which part numbers to order.Type "w-1013c" into the Store search field on vansaircraft.com, and you'll see the 4 related parts (2 left, 2 right).
Right. I did it, too. Thanks.I chose to do this SB while at this stage of the build.
SB 16-03-28-1014
store.vansaircraft.com
I believe the SB is only for the inboard aileron bracket assemblies and those parts were included. Since I'm building a 14, I started at step 20. The two parts for the outboard bracket were supposed to be in the wing kit but I guess I missed spotting their absence during my inventory.Did you not receive updated parts in the SB kit? The parts in post#1 that you’re looking for are all replaced.
Yeah, they should do that but it's probably a lot easier (for Van's) to keep it as a (confusing) SB than to incorporate the changes into revisions of the main plans.Yes, you’re right it’s only for the 2 inboard brackets. I’m amazed that Vans hasn’t just incorporated that relatively small revision into the kit and done away with the SB.
