Hello,
Wondering why Vans came out with the "gun drilled" main gear legs? Notification N 19-02-28 states that this is an upgrade. The synopsis in the notification is vague to me on why the notification came to be. Other than the brake fluid passing through the gear legs therefore eliminating the brake lines, is there any other benefits to the upgrade?
Although not mentioned in the synopsis, I wonder if corrosion had anything to do with this?
Has anyone experienced severe corrosion with the legacy gear legs?
Thank you,
Jack
Thank you,
Jack
