cover
bob dobolina
I'm New Here
RV-4 Does anyone have ideas on how to cover the opening in the floor that has the fuel filter, control stick and trim relays? Seems dangerous if something fell-in and could jam the stick.
Here's a solution.........
Off the subject. Our RV doesn't appear to have a fuel filter except a strainer on the engine side of the firewall and the inlet to the carburetor. Should I look in another place.
G Harben
O 320
N12HR
RV 4
Fuel filters
RV 4
Sometimes they are placed in the wing root between the tank and the fuselage..... Also: Check under the floor boards (in front of the spar) where the fuel lines come in from the tank and where the fuel selector valve is. Some were built with no filters other than those you have found already....:)
More "hole cover" pictures....
Hey, Mark!
Thanks! I really like my panel and cockpit area. The panel took a long time to figure out exactly where I wanted everything to go but I really like it and would not change a thing! Steam gauges? I'm OK with that! It is now very familiar after 1200+ hours. The cockpit fits me like a glove! I have her apart now to make some changes including a Dynon 10A where the Rocky Mountain instrument was in this (old) picture. ADS-B is also being fitted. Meanwhile the Cub is getting some action!
Stick "glove": I made it out of a thin Naugahyde that was hand-sewn up the back. I made the initial pattern out of canvas first. The velcro is machine sewn on the back side as you can see in the picture.
The hole cover is incorporated into my center console (not seen in this picture but in the first one sent) and has a hole for the glove and also a fitting for the tank selector valve. There is a small spring steel stop that prevents the fuel valve lever from being turned to "off" without deliberately depressing that stop.
There is nothing I don't like about this airplane!!
Let me know if you have questions....
Michael.
This is how I did mine.
Here is how I did it. Included a nice slot on top for tucking stuff into.
