WhirlWindPropellersCorp
I'm New Here
Hello Everyone,
We just want to clarify a couple of things about our 300 Series and 330 Series C/S propellers and hub mounting drive lug configuration.
First, the easiest one, all Whirlwind C/S propellers have the standard drive lug configuration (length of drive lug) as called out for Lycoming engines configured for C/S propellers. This standard was set by Lycoming many decades ago. McCauley, Hartzell, MT or any C/S propeller interface to the crankshaft is the same for all Lycoming engines with the exception of 320 vs 360 (5/8 drive lugs 7/16 studs vs ¾ drive lugs and ½ studs- respectively).
Below is a basic overview for our 300 Series and 330 Series of Constant Speed propellers:
-The 300 Series propeller is a light weight and efficient propeller with a 3-blade constant speed system designed for 4-Cylinder Lycoming, non-counterweighted engines (0320-160HP and 0360-180HP), straight valve 0540-260HP, as well as counter weighted angle valve IO-360-IO390 engines. There are some compression ratio limitations with the 300 series propellers.
-The 330 Series 2-Blade propeller has the same 4-Cylinder Lycoming engine applications as the 300 series propellers.
-The 330 Series 3-Blade propeller is basically can go with all the engines already mentioned as well as everything else. Meaning, all the non-counterweighted angle valve IO-360 and all Lycoming IO-540’s through IO-580’s engines. No compression or ignition restrictions with these propellers.
Attached are 300 and 330 propeller application data sheets that go in more detail than the general overview mentioned.
Best regards,
Whirl Wind Propellers
Best regards,
