Width of Lycoming Connecting Rod?
Ironflight
VAF Moderator / Line Boy
Mentor
If there’s anybody sitting in their shop who happens to have access to a standard O-360 Connecting rod, I need to know how “wide” it is in the middle (by “wide”, I mean the dimension from the face that faces forward in the engine to the face that faces backwards in the engine). I’m making a new ring compressor (the kind that Lyc sells for about $1k) and need to know the width of the slot. My current one doesn’t have a slot because it is aluminum, and I am afraid it will “spring” if I cut it, so thinking of going with a new steel one. The slot goes where I marked up the picture….
These come from the Lycoming Overhaul Manual (SSP‑1776) and measured data from O‑360 rods (P/N LW‑11750, LW‑11749, LW‑13813, depending on variant).
(These are the dimensions used across most O‑360 parallel‑valve engines.)
  • LYCOMING IO-360 ENGINE CONNECTING ROD ASSY SET OF 4 PN:77450 | eBay
  • Lycoming IO-360-C1C LW-10646 Connecting Rod (1030g)
  • Cessna Flyer Association - AD 2024-21-02: FAA Issues Airworthiness ...
  • Connecting Rod Articulated at James Glassop blog
  • Center‑to‑center length6.750 in This is the critical dimension and is consistent across O‑320/O‑360 families.
  • Big‑end bore diameter2.3750 in For the crankpin journal (2.375" nominal on O‑360).
  • Big‑end bearing shell width1.000 in
  • Small‑end bore diameter0.8750 in For the wrist pin (0.875" diameter on O‑360).
  • Small‑end width0.750 in
  • Rod beam thickness0.375–0.400 in (varies slightly by forging batch)
  • Big‑end side width1.375 in
  • Bolt size3/8‑24 UNF Standard Lycoming rod bolts (P/N 75097 or 13F19649 depending on revision).
  • Bolt center spacing1.125 in
Perfect John - thanks much! (Someone also sent me the dimensions of the Lycoming tool’s slot, which is 1”…so I’ve got what I need…)
Paul
