As I finish up my FWF work, I am realizing just how tight the space between the engine and firewall get! I've primarily used crowfoot wrenches and have chopped down my fair share of cheap pawn shop wrenches to try to fit in various spaces. I'm just curious what your go-to tools are to make life a little easier in terms of future engine maintenance. I think I'll be buying a stubby ratchet for one - my smallest ratchet is a 9" and doesn't have much room to swing without hitting stuff around the engine/firewall. A flex head ratchet might be useful as well. Also on the list is to find a set of super thin wall sockets - even my "thin wall" are too thick in some cases (like getting at that lower/inside nut on the backup alternator that sits against the spacer for the 90 degree oil filter adapter - I had to do a million, two finger only 1 mm turns using a chopped off wrench that was about 2" long).
What do you use when doing maintenance on the plane to keep the cussing to a minimum?
