The VAF News - 6.19.2025. #6365.
DeltaRomeo
doug reeves: unfluencer
Staff member
RE Baggage Lights
…wnpit PIREP
RE: Brass Fuel Selector Disassembly
…Ruready
DanH
Tony Kirk
RE Dismantling a project (12)
I'm certain that both fuel lines (F-12127B & F-12127C) in the center forward tunnel can be made "in place", even with all of the other systems installed. Some things will need to be disassembled or disconnected, but it can be done without any "surgical" modification to the airframe. I know because I've done it!
The fuel line will have to be bent to final shape in place after both of the flares have been made and it is a VERY difficult area to work in, but it can be done.
Raymo
RE MA4-5 upgrade?
…YellowjacketRV9
I have experimented to great end with this. Some pictures below. You can clearly see when the front two vs rear two cylinders are richer/leaner with different throttle position. Oddly, when settling down at cruise my #2 is about 100 degrees lower than the other 3, which even out. If I climb high enough to stay below 65% power at WOT, I can crack it just a bit and get them all just about the same, however.
https://vansairforce.net/threads/ma4-5-upgrade.235697/post-1851088
RV-14 Kits F/S. $50K
FireMedic_2009
OFF TOPIC:
