WDYDWYRTW? May 16-17, 2026
Here's 1030 CST Saturday. Lots of RVs a hoppin' Hope you're having a good weekend, and looking forward to reading the activities. v/r,dr
vansairforce.net
Chasing "heavy wing" (Was "N612EF: First flight report")
N612EF had its first flight this morning. Because KSGS doesn't allow experimentals in Phase I to return, DAR Tony Kirk gave me a corridor down the Mississippi to near Red Wing, at which point I could turn north into the test area and then, finally, head for Lake Elmo (21D) where it will be based...
vansairforce.net
3D printed tailwheel pant
I hate to cover up my nice new aero garage tailwheel fork, but I think this tailwheel pant might be worth 0.5kts. I used the NACA0030 foil because it seems to fit well over the height and width of the tailhweel/fork assembly. It should index over the OD of the AN5 axle nuts and into the ID of...
vansairforce.net
Cheap Towbar rebuild experiment
So after 20+ years and over 3000 times dragging da plane out da hangar, the towbar needed some TLC. The spring broke, the powder coat was mostly missing, and it looked sad. The county just opened a paint recycling store, so as a cheap guy, that called to me. I found these gems and a new...
vansairforce.net
Jacking up a RV7
Can a RV7 be jack up from the tie down points on the bottom of the wing?
vansairforce.net
RV-15 #150118
Finally got the Wing Kit(minus the Spars) late last week. Delivery was ABF and they got it here in good time. All appeared in good shape on the exterior of the boxes. Until.... Things went a bit sideways(literally) when I opened the big wooden crate. The airline words, "Items in the...
vansairforce.net
Adding Dynon servos to F1 Rocket?
Anyone here added Dynon autopilot servos to a Rocket? My concern is that “older” RV4s need a different elevator bellcrank retrofitted to accommodate the servo (per Dynon). My Rocket has a RV-4 tail made before 2005, so I think this applies. Is there a better way to install the pitch servo?
vansairforce.net
Bleeding brakes the easy way
Bleeding brakes can be a challenging and messy job; however, I have been using a system for years that works so well it's almost hard to believe. I first saw this method being used by Jay Pratt, and I shamelessly made my own version. My older version had a bigger and ungainly tank, so I decided...
vansairforce.net
OFF TOPIC:
https://vansairforce.net/threads/the-vaf-list-a-list-of-rv-related-lists.223964/
vansairforce.net
Past ‘VAF News’ issues:
www.vansairforce.net
