The VAF News - 4.14.2025. #6318.
DeltaRomeo
doug reeves: unfluencer
Staff member
Spent the weekend at job2, heating up cans of beans on an inverted iron LOL JK. Hope you got to spend some time with your RV, and hoping to take the -6 up for a spin here in a few days if the schedule and Wx permits. Miss it!
Have a great Monday.
v/r,dr
dr
bertschb
280FX
RE Rear Seat Display
…RV7 To Go
I just put an old D1 I had laying around for the back seater. Can't put anything behind the seat back since I made a compartment to keep my journey log and sick bags in.
Schumway
Mburch
drone_pilot
Bicyclops Update on Rough running while accelerating
It's been a while, but my issues seem to have been resolved. Firstly, I cured the leak in the manifold pressure sense line. My fuel servo and fuel distribution spider were overhauled by AFP. There is now no hesitation coming off idle with advancing throttle. After mounting up the servo, my number 1 ignition failed an inflight LOP stress test, so I replaced the spark plugs and wires.
While I was at it, I bought a type 2 ram air/filter setup from HP Aircraft and modified it to fit my cowl induction scoop. I got a test flight in today and the first results are very encouraging. She took off normally with the ram air flapper shut. I set up a lean of peak cruise and did another stress test on the ignition. It's much better. I climbed to 6500', was lean of peak at about 8.8gph, WOT, and saw about .2" increase in MAP when I opened it up. The airspeed increased by maybe 2 or 3 knots, much more than I expected. I played with it for about an hour and it seemed to be fairly consistent. I took a few screenshots but forgot to bring an SD card with me. I'll be playing with it more and so far it has exceeded expectations.
KLRDMD
(second half in next post)
Seagull
I have made and replaced the little spring piece. It is made of music wire and wears in the area where it contacts the threads on the plug. You can use a flat blade screwdriver to unscrew the brass insert to access the “spring”. This fix will work for a while but what is wearing is the brass tube that this spring holds the plug threads against.
The new spring is on the left, notice the wear on the right one.
Larry KMYA
Bertschb
OFF TOPIC:
