dr
RE: Adding the GPS 175 to the G3X system in an RV-12is
….mhailey
Noah
Larry Gray Wrote a Book
….a plug
SwimmingDragon518
Daida
ymc9
OFF TOPIC:
WDYDWYRTW? 3 / 22-23 / 2025
Getting this weekend's thread started. Here's the RV activity in a slice of the United States at 11 AM Dallas, Texas time. Hope you're having a wonderful weekend. v/r,dr
vansairforce.net
….mhailey
I wanted to start a thread that may hopefully serve as a roundup for information on adding the GPS 175 to an RV-12is with the G3X system. Especially the dual PFD/MFD system, but the configuration is similar enough the PFD only should fit in. Ideally this thread will on-topic with technical...
vansairforce.net
Noah
Leak at Spark Plug Gasket, Lyc Special Tools ST-369, ST-370
Doing a compression check, I heard air escaping and had trouble sealing the pneumatic fitting in the spark plug port. Careful inspection showed a scratch or dent in the cylinder head, just adjacent to the spark plug port, where the gasket goes - hissing and bubbling with snoop leak detector...
www.vansairforce.net
….a plug
Building a Kit Airplane: Everything I Wish I Knew Before I Started: Gray, Elby: 9798344104454: Amazon.com: Books
Building a Kit Airplane: Everything I Wish I Knew Before I Started [Gray, Elby] on Amazon.com. *FREE* shipping on qualifying offers. Building a Kit Airplane: Everything I Wish I Knew Before I Started
a.co
SwimmingDragon518
Increased fuel flow with boost pump (not a reading error)
I posted a likely too long thread earlier about a ghost I'm chasing in my RV (RPM fluctuations on takeoff). One thing that is clear is that I have is that I am getting increased fuel flow when I hit the boost pump before takeoff. I have a carbed O360-A1A with a CS Hartzell on my 7A with a...
vansairforce.net
Daida
Christen inverted oil system 802 Oil (Ball) Valve overhaul kit?
Hi folks! The lower „head plug“ (the plate held in place by an snap ring/circlip/retainer) is leaking some oil…. Not as much to be really worried about, but enough to make the belly look awful after 2 hrs of flight. I want to overhaul the valve and replave the o-ring, plate and retainer. I...
vansairforce.net
ymc9
Tiny dents on the wing's bottom skin
I managed to make a few tiny dents on the wing bottom skin. When pealing the blue film, I thought I had a good surface beneath, but I didn't. I'm wondering if it's worth trying to fix them. I think they're cosmetic, especially on the bottom side of the wings. Will the painting eventually cover...
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
