The VAF News - 2.19.2025. #6280.
DeltaRomeo
doug reeves: unfluencer
Staff member
Vlad Crushing the WDYDWYRTW thread from last weekend.
“It is howling at my airport bench all week. Managed to find a slice of relatively smooth air between 8200' and 9500'. With partially taped cooling air intakes CHT stayed at 375. OAT -15C. It took almost an hour to bring oil temperature to 180F.”
…and crabandy knocks it out of the park with a FOV we’ve all seen.
RossK
Countersink in fiberglass wing tip for a dimpled skin.
…BravoAlphaRomeo reply
You can also consider taking the roughly 1” edge that you cut off the inside of the wingtip and rebond it back on the inside
of the new edge. Scuff up both mating surfaces, a little resin w/flox. This adds some ridgidity and volume for when you ultimately C/S for the dimples described above. I did this, and am happy with the result. YMMV.
Ron B.
BruceW
YME
OFF TOPIC:
