The VAF News - 11.26.2024. #6222. Tuesday edition - Thanksgiving week 2024
DeltaRomeo
doug reeves: unfluencer
Staff member
Oil Change / Battery Change Underway
Started it Monday a little before lunch, then back home for computer work. Sim called asking for help, so the oil has to drip for a bit <g>. At least got it started <g>.
v/r,dr
dr
petehowell
Status Report
…David Paule -3B
The throttle, mixture and governor controls are hooked up. Can’t hook up the carb heat control just yet. The main impediments at this time are that the control’s firewall pass-through itself isn’t located, and the FAB hasn’t been built yet. Minor things.
FireMedic_2009
…alternator field wire.
The plug on the back of the alternator is the T style plug. If removing power to the wire doesn’t shut down the B-lead then how else would you disconnect it from the bus without a contactor?
ebackscheider
N8DAV8R
OFF TOPIC:
