dr
Nitty
LykkeEspersen
cjs
bertschb
Little Wing
WayneJ
00068
Rv-12David
https://vansairforce.net/threads/00068.230434/post-1799268
sophistical
OFF TOPIC:
WDYDWYRTW? (Oct 19-20, 2024)
...getting this weekend's thread started. Hope you're having a great weekend! v/r,dr
vansairforce.net
Nitty
Request for dimensions
I need to remove my engine from the firewall and was hoping to keep the engine and engine mount together when I do remove it. I'm going to bolt the engine mount to a steel plate and bolt the plate to an engine stand but I need to know the dimensions of the bolt centers at the 4 corners of the...
www.vansairforce.net
LykkeEspersen
Corrosion in Aileron Push Pull tube
Both of my aileron push pull tubes have corrosion on them. One is worse than the other. I seem to remember that 10 % of the thickness is the limit before it has to be replaced. Is that correct?
vansairforce.net
cjs
RV 14 overhead console
I heard of an individual at OSH who can make an overhead console for a RV-14. Anybody have any info on it? Thanks in advance.
vansairforce.net
bertschb
Aileron: How to rivet?
How do I rivet the rib to the spar? I can't squeeze the rivets and I don't have anything small enough to get into the slot with the riveting gun nor a bucking bar. I guess that I could remove the plate on the end and put it on again after riveting to the spar. I must be missing something...
vansairforce.net
Little Wing
Wing wiring
Hello, TIA I’m working on my -8 wing wiring/routing. I’m Using The recommended size of 5/8” holes from the bellcrank area to the wingtip/wing root ribs by opening up the tooling holes. I am debating using conduit and or just the snap in bushings. Has Anyone experienced issues with just the snap...
vansairforce.net
WayneJ
Dynon roll servo push rod interference, RV-14 Page 57-05
I installed the Dynon roll servo today and have an interference problem. See page 57-05. The M3441M Rod End Bearing on the Roll Servo Pushrod (57-02) contacts the W-823-AP Aileron Bellcrank Bracket and limits down aileron travel to about 6 degrees when it should be 15-17 degrees and limited by...
vansairforce.net
00068
Rv-12David
sophistical
Bypass for heated air (older RV4)
I purchased a 1990 era RV4 this fall. The plane has a cabin heat valve inside the firewall which is just an open/closed valve so it tries to block the air at the firewall when closed. There is no bypass for the air when the valve is closed; the ram air from the #3 baffle was just dead-headed...
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
