paulsmeds
rocket bob
skelrad
tims88
Spotlighted Classified
jackking123
Rbb469
EdH
RV-8 seen on the ramp at Tuesday’s XB-1 Flight
OFF TOPIC:
O-360 Carb Fuel Pressure Spikes 25PSI Real?
I'm pretty sure this is a sensor problem but thought I'd check with the group that I should consider something else is wrong. I'm seeing some spiking of the fuel pressure from a steady 6.5 PSI to 25 PSI instantly then back down, then mid-teens then back down. After a bit it steadies out back to...
www.vansairforce.net
rocket bob
Pin identification
Looking to source where I can get these dsub crimp connector pins for larger wire gauges. These have a bit of clear heat shrink over the portion that wont fit in the connector body.
vansairforce.net
skelrad
Fuel Pump Fittings
Educate me - on my fuel pump lines from Aircraft Specialty, some lines have nuts with the sleeves, and some have nuts that have no sleeve. Why the difference? For example, this line going to the pump - one end has a nut/sleeve and the other end just the nut. The line going forward from the...
vansairforce.net
tims88
How can I tighten this bolt in WD-1021 landing gear mount?
I have the old style of landing gear mounts and I'm finally getting around to bolting them to the fuselage. The aft hole in the support that extends forward to the front floor ended up in a spot that is very close to the post from the main mount body. This doesn't give me enough room to get a...
jackking123
RV-7 Lower Wing Inspection Covers TOO thick?
So nailing up the lower skins really getting a good fit of access / inspection covers. The cover thickness is greater than the joggle depth, so it sits appears proud of skin slightly. I did not screw then down but seems so? Question is this normal cover fit for RV-7??? BTW FYI mine is an...
vansairforce.net
Rbb469
Canopy gap on both sides
This is my first -4! Is this a normal fit for a -4 canopy? Both sides are equal in their respective gap space. Thanks for any input. Ricky.
vansairforce.net
EdH
Whose RV-8 at Mojave behind Boom XB-1?
Boom Supersonic's XB-1 just went supersonic… but whose RV-8 is that?
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
