WDYDWYRTW? Jan 24-25, 2026
What did you do with your RV this weekend? Sort of a stay-in-the-shop Sat and Sun here in N.TX. Fortunately, being Texas, all this snow and ice should be gone in about 48 hours. Car washes will be busy and the GA planes back in the sky. Hope less snowy and icy in your area. v/r,dr (went to...
vansairforce.net
RV-10 N720AK First Flight, complete with missing airspeed
I took N720AK up for first flight on Thursday, after 10 years, 7 months and 4 days of building. It is a surreal feeling to lift off of the ground, sitting in the same spot I've sat in so many times in the hangar, fiddling with waxed lacing tape. It's been a slow transition from seeing the plane...
vansairforce.net
old farts forming up for another season
Treasure Coast KFPR Invite… For Thursday, May 2nd, 2024… https://us18.campaign-archive.com/?e=985d565717&u=c4993321b97ea47e644911b20&id=732eecc91b Time to head to the Coast… Treasure Coast International KFPR. I’ve talked with Frank at APP Jet Center. I’ve talked with Jennifer at the Tiki...
vansairforce.net
DIY vs purchased carpet kits
I am opening up my RV10 for an assisted condition inspection. For about half the carpet, it seems like I would need to remove the seatbelts to get the carpet out. I cut the carpet holes larger instead of doing that. The remaining carpet already had larger holes. It looks all jacked up and I...
vansairforce.net
Firewall Passthrough Removal or Capping
Hi, I'm doing some work on my new-to-me RV-8A, and found this unused firewall passthrough. I'm wondering if there is a good solution for eliminating an unnecessary breach in my firewall. I'd prefer an easy solution - e.g. a solid cap that fits on the existing threads, or a new fitting that...
vansairforce.net
Tailcone Transport Frame
The RV-12's tailcone is a real PITA to transport, because it is nine feet long and floppy as a wet tortilla. Here's a fix, assuming you have some scrap steel and know how to weld. It's a simple frame with tabs match drilled to the overlap seams. A handful of clecos does the rest. A person...
vansairforce.net
Aerosport NACA servo and controller
I have the NACA servo and controller and from day one it’s sort of worked but not very well. Recently I’ve checked it and it’s not working. Has anyone come up with a better system than what Aerosport provides to control the two butterfly valves via the servo? Thanks
vansairforce.net
OFF TOPIC:
vansairforce.net
Past ‘VAF News’ issues:
www.vansairforce.net
vansairforce.net
