The VAF News - 1.16.2025. #6256.
DeltaRomeo
doug reeves: unfluencer
Staff member
Daily RV Pic
…Vlad the Amazing
N42AH
My solution...modified anti-splat. Locks the rudder pedals as well as the stick.
RE: Rudder Stop …bjdecker
I've used them (and a knock off I made with a cutting board) on my -7's, and the -14 builds; love em. The only change I would suggest is to mount them in between the VS-410-PP halves instead of as shown on the website. This will require some pre-fit, templating work to get the holes to line up.
Completed 14 …G5Driver
RV8JD Sump Heater
Tdeman Optimizing Engine Cooling
I started my own cooling optimization project this week on my RV-4. Quick background, during phase 1 in the 100 degree CA Central Valley (with a new engine not-yet settled) the bottom of the cowl was trimmed a fair bit to get temps under control. Fast forward 75 hours and the engine temps have not only settled, but run quite cold up in the Oregon climate. Both CHT and Oil temp. Additionally, my top speed is a fair bit lower than I expected. I’ve been busy, and enjoying flying to much to tear back into it, but I’m finally getting around to it…
Before tackling other speed mods, I figured I’d start by getting my cooling closer to optimal.
My first step was to close off some exit area to get an idea on where it could be. This was half a WAG, half based on similar aircraft exit areas, and half based on what would conveniently line up with the existing forward floor ribs once a a ramp and cowl flap needed to be attached. With 1 and 1/2 decision made ;) , I chopped and bent up a piece of .040 and fastened it to the motor mount via Adele clamp, and the bottom of the cowl.
Yes, this is rough, not smooth flowing, and the tufts would be going every direction but aft if they were there…. But i figured it’d give me a second-baseline to improve from.
Moshonsk
OFF TOPIC:
