Landing gear removal
Lufthans
Hi guys,
I'm rebuilding my RV-3B and fitting a turbocharged Subaru engine.
I currently have the engine mount and landing gear off as one unit, have modified the mount to accept the Subaru and would now like to coat it. And even though I could in theory leave the gear legs in place and work around them, I would rather take them out, media blast the modified engine mount and then either spray paint or powder coat it.
How hard is it to remove and later re-install those gear legs? Is it a matter of removing that one retaining bolt and tapping them out, or would it be more involved?
Thanks!
Hans
Yes, there is only one bolt in the gear leg. Carefully knock it out, save it and the gear leg SHOULD slide out. May need some penetrating oil and a tap from the upper end. Hopefully, it was installed with some grease or coating and not frozen. You will see it's a "coke bottle" shape (inside the socket) and not solid diameter. This is on purpose so the gear can actually flex inside the socket.
Thanks Bill.
Sometimes it's a matter of "Just do it", I guess.
The Insides were lubricated and they slid right out.
Ok, off to the powder coater it is then!
Thanks again,
Hans
Hey Hans - glad you got the legs out! Before you head off to the powder coater, consider that there is a lrge school of thought that powder coating can hide cracks if/as they form later on, while paint doesn’t. Yes, powder coated steel tube parts look really nice and the finish can last longer - but painted parts can look just as nice, and if you have paint come off and the steel underneath shows signs of rust, the congratulations - you have an engine that doesn’t leak a drop of oil! 😉 (I have found that the little oil that comes out of most engines tends to keep motor points naturally corrosion-resistant….. whether you want it or not….)
Hans, you might consider Cerakote. Specifically the C-Series Air Cure. I used it on wheel pant brackets and a few other places and it has held up extremely well. Very easy to apply even for an amateur like me. Below is from their website. No connection, just a satisfied customer.
  • Formulated to withstand temperatures up to 1800°F (See individual product descriptions for specific temperature rating)
  • Single component, ready to spray
  • Direct to substrate - no primer required
  • Over 50 colors available
  • Excellent UV Stability
  • Great option for large or small parts that cannot be oven cured
  • Extremely high chemical resistance
  • Uses: Automotive, wheels, exhaust systems, firearms, architectural, lighting, hardware, optics and much more
Valid points. And yet... I always powder coat my engine mounts white for this very reason. And guess what after 20 years my Jodel showed me last year:
Two conclusions:
1 - the cracking is not something academic that just doesn't happen in real life. In fact, it does
2 - the powder coating doesn't necessarily hide cracks.
Still, N=1. So still valid points....
Interesting stuff. Thanks!
