GPS Repeater
Rallylancer122
Patron
Any recommendations out there for a GPS repeater for my hanger? I find myself doing lots of avionics troubleshooting and it would be nice to have a GPS signal inside instead of pushing the airplane outside. I tried a $20 one from Amazon and it didn't work. Google turns up some expensive ones but I don't need one that bad. Hoping someone here had some success with a budget solution.
I believe that this is the one that I have. I found that you have to close the hangar door and have the receiving antenna far away from the transmitting antenna. I usually set the receiving antenna up on a tripod outside the hangar and around the corner and then put the transmitting antenna right next to the aircraft gps antenna.
