fuel tank drain questions
dbhill916
Friend
Patron
I'm having some problems threading the Saf Air SA-187 fuel drain into Van's VA-112 on my right tank. It feels like there are no threads to engage on that one and I'm tempted to chase it with a tap. Are there any reasons I should not? If none, does anyone know the thread size/pitch?
Once I get that taken care of, page 21-13 is silent regarding the use of any sealant. Should I use B2 fuel sealant or Loctite 565 ?
thanks in advance,
-dbh
I don't think that will be a problem but I would be inclined to only clean it to just the first few threads so that I could get the fuel drain started....
I have not used thread sealant on my fuel drains and have had no issues. (I think pipe thread has a bevel for sealing.)
My recommendation is for reading the Pipe Thread fittings portion of Chapter 5.27 in Section 5 of the KAI.
Standard pipe thread is not 100% self sealing without sealant.
And, if you decide to use a tap, make sure it is a 1/8" NPT tapered tap
