Fuel pressure reading half.
RV8iator
Benefactor
To the collective group..
Old fuel pressure sender for injected 360 started reading intermittently high. I’ve been through several over the past 16 years and 3200+ hours. Always the same VDO 2 bar units. Some with ground wire, some without.
My latest unit from Vans, correct part, without ground stud, now reads exactly half of normal all the time.
Other than a bad unit out of the bag, any other ideas?
Hey Widget---connet a direct reading guage to verify the actual fuel pressure first--
Tom
Did that. Pressure’s normal. Sender reads exactly half of real pressure. Wondering if lack of ground is the problem. Sender has a cover over where the ground stud is. Will see if I can remove and put a ground lug in. ‘
I'm thinking it's a faulty new unit. I have another extra but just wondering if any other way to make it work maybe. Hate throwing money in the trash.
