Got some strange oil temp readings last flight during descent. Oil temp in a few seconds rised to 340 F, then a short stop (2 s) of registration then a similar drop to more normal values. However indicated temp fluctuated rest of flight. All other engine parameters fully normal and stable during flight.
So, most probably probe failure or wiring. I tested pulling in all wires during a ground check, only normal indications.
Leaning to recrimp the connection from sender to harness to start with, but not easy to troubleshoot intermittent problems.
Seems after a search that there are a few who had same problem. Recrimping not solving the problem. So maybe best to order a new probe?
Probe is a Garmin UMA 1B3-2.5R, connected to G3X. Probe mounted on top of engine close to oil filter. IO-360-M1B.
