The holes for the wing tiedowns in my QB RV-10 kit were too small to use a jam nut. Using a jam nut is important to keep the threads in tension to avoid cyclic loading on them. I needed to open up the skin hole a bit but I wanted to keep it as concentric as possible and also not damage the threaded fitting inside. I ended up drilling out a 3/8-16 hex bolt and then turning down the hex portion on the lathe so it would fit inside a 5/8 piloted hole saw. When threaded into the tiedown, it provided an arbor for the hole saw. I went slow and stopped as it broke through the skin. I opened it a bit more with a deburring tool and used a dremel with a small scotchbrite end to get the edges completely smooth. The jam nut still sat a bit deep so I added 2 washers so I can get a wrench on it.
I’m sure there are other ways to do this but just wanted to pass on what worked for me.
