Hi thanks in advance for any help you can provide.
I have been putting off figuring out how I am going to tie the lower baffles together (titan 340 with tapered barrel fins). I decided to try rods as this is my first engine install and safety wire seemed a bridge too far for me.
Anyway, I planned on making them out of stainless rod, and I would have to turn the ends on the stainless stock to thread 6-32. However, I did find some O1 tool steel rod right on dimension so I grabbed that too and did a fit up. THe stuff bent and threaded easily.
So the question is, how bad will these corrode? I really dont want to remake these in stainless (303 I think it what I got) if these O1 rods will work (lazy is all)
If I have to do something for the corrosion, I suppose I could go ahead and heat treat them and anneal them, if memory serves they will be pretty robust after that process but I dont want to do that either if I can get out of it.
Matt
Matt
