As an example of what we can do with 3D printing here are 3 of photos of my RV6a:
The following parts are all 3D printed on industrial printers:
-The panel
-Center console with flip out iPad lap desk
-Little side gusset trays with head set jacks
-Side trim panels with arm rest that opens to reveal a small storage compartment for pens, batteries, fuses, etc
-Fuel valve and fuel line bezel
-The knobs for carb heat and oil cooler. (these were done with polyjet photo cure technology so the text is imbedded about 1/2 mm deep)
-The AOA display hood on top of the panel
-The labels on the panel. (several layers of solid white then a top layer of black with open text to reveal the white below). The panel was inset for these labels making them inset as well.
-Glove box that happens to be the same size as a Dynon Skyview 7" display (should I ever want to add one)
Nearly all parts are Ultem polymer for aircraft interiors.
(I dont count on the CO card for CO monitoring. That was a temporary test and I have a real monitor now)
The panel was particularly fun. The radio tray and ribs to attach wire bundles were all printed as a single piece. All of the nuts and screws are inset and covered by labels. The panel is about 1" thick with a light but stiff honeycomb type internal structure. If I did it again I would add back lights and ductwork directly in the panel.
-The panel
