Strange engine problem
Gino230
Patron
2 weeks ago, all of a sudden my RV8 (IO360) became harder to start. Even cold, used to start of the first blade, and hot maybe on the third but suddenly it's taking up to 2 cranking attempts cold and worse when hot.
When I failed to make a flight 2 weeks ago due to failure to hot start, we took out all of the plugs and cleaned them, (some lead fouling but not too bad) but #3 and 4 had lots of fuel in the plugs, it was actually dripping out. Plugs have about 35 hours on them.
So now my start procedure has "evolved" to basically more throttle opening (i.e. more air) and less prime to get it to start, hot or cold.
Once running, I noticed today that #2 is running higher EGT than all of the other cylinders. It's always been the hottest but now it's the hottest by 150+ degrees.
CHTs are all normal and within 10 degrees of each other. This plane runs cool, I've never seen over 350.
Fixed pitch (Catto 3 blade) so power settings are a bit of a dance. Old school EI engine instruments so I need to click back and forth to see each cylinder temps. NO fuel flow info.
Generally run ROP 75% PWR.
Today in cruise. Leg 1 6500'
22.2" MP
2670 RPM
67F (OAT)
Cyl #1 EGT 1276, CHT 302
Cyl #2 EGT 1420 CHT 324
Cyl #3 EGT 1264 CHT 309
Cyl #4 EGT 1339 CHT 310
Leg 2 5500"
22.75" MP
2620 RPM
69F OAT
Cyl #1 EGT 1297 CHT 300
Cyl #2 EGT 1450 CHT 319
Cyl #3 EGT 1288 CHT 310
Cyl #4 EGT 1356 CHT 312
Plane is flown weekly, so any time something suddenly changes I'm wary.
My current theory is #2 injector is dirty (has the most exposure to the airstream due to its position in the cowl opening) and forcing more fuel into 2,3,4 making it rich on start. And of course #2 running leaner.
Any thoughts?
I was attempting to find LOP operations today and #2 was getting to 1499 before peaking- (it's the first to peak) and RPM is dropping smoothly at this point. I know 1500 is about the max you want to see and with the current spread I don't think I can run LOP as #2 will be well LOP while #s 1,3,4 will be peaking. But that's a discussion for another day?
My limited experience is a change to starting reliability, especially when cold, are often ignition related, not fuel.
Are you Mags or EI? .
Mags
No sniffle valve
Mag timing was my second thought, perhaps the mag timing is off? CI it was checked with the buzz box and that was 60 hours ago- April 2025.
Have not turned the prop through by hand in a while to see if I hear the "snap" to make sure the impulse coupling is firing.
Once engine is running, Run up, mag drop, etc. seem normal
Mags
No sniffle valve
A bad or weak impulse? Even if you hear it click through, it may not do so when the starter is swinging it. I had this happen and had the same start issues you did. Ended up being an improperly manufactured impulse on the Mag that took years to start to fail.
When I spoke with a well known injector guru, he told me start issues like this are rarely fuel which led me to send my mags in.
He was right. However, my servo was due for overhaul and the spider and servo went in for a refresh. Nothing wrong with them.
It was the Mag impulse.
A 150* rise in egt above normal or typical is a classic sign of running on one plug. If the bad plug, wire, etc is on the ignition that you are starting on, that could explain the harder starting, but should also be rough before adding in the second ignition. Once on both ignition, you can’t really feel the difference, but the 150 egt delta confirms it.
Check your #2 plugs and wires for issues. Anin flight mag check should help. If the #2 is dead on one, it will be very obvious on that test.
If you confirm that #2 egt is 150 high and all 8 plugs are firing, then next step is to clean out the #2 injector. Likely a partial blockage.
Both harnesses look good on the outside, but the white insulator(s) are a little beat up and we planned to replace them this CI.
I will pull #2 plugs and see which one looks worse- with 1450 EGT they should not be fouled.
Impulse is on the left mag so theoretically this would be more likely to be the problem plug / wire?
If this were the case, that would be a hella rough engine on the run up mag check? Mag check has been normal.
Appreciate the advice as always.
Yes, that would next point you to a partially blocked #2 injector. As lomg as the indicated egt is at or below the official peak egt for that cylinder, the problem can be fuel. If it is above the peak, it is typically ignition.
How long since the mags have been internally inspected/adjusted?
Incorrect internal timing (E-gap adjustment) causes a reduced output voltage. This is most noticeable during start because of the slower rotation speed of the magneto.
Once the engine starts, the issue tends to have a much lesser effect on engine performance. If the mag is correctly timed to the engine, the mag check rpm drop and overall engine performance typically seems normal.
The internal timing drifts because of points wear.
This is the primary cause for needing to readjust the mag to engine timing.
Once that has been required a few times, the mag internal timing has probably drifted enough to cause a noticeable change in starting performance.
This is not necessarily the cause of your starting issue because there are other potential reasons as well, but this is a fairly common one.
The mags have about 200 hours since the removal and 500 hour inspection. We timed them with the buzz box at last CI (April) and the plane is flown weekly. If I recall, the left mag needed a tiny adjustment then- mag to engine, NOT internal. The mags have only been moved once (this last CI) since the 500 hour inspection.
My concern is that something "acute" happened which started this issue. One day it was fine, the next day all this trouble started.
Like I said in one of my other posts, the harnesses are due for replacement, also. The insulators are chipped on a few of the wires, so that is going to get done asap too.
How does this stuff always happen when you have plans to fly somewhere? Kind of like the AC in my house that knew when to break- first 90 degree summer Sauturday.
Probably my fault as I've been telling everyone how trouble free the little RV is.
My guesses:
First is you're correct. Injector clogging on number two causing it to run lean. Could also be at spider and not injector.
Next thought would be that there might be an intake leak on the number two cylinder. Check your intake gasket clamps are tight.
Could just be probe issues
Lastly, hopefully not but could be an exhaust valve. How is your compression?
Your issue seems to effect only one cylinder. So I have a hard time believing its timing related because I assume it would radiate to all cylinders equally. I could be wrong, others here would know more.
To get LOP EGT only matters that they all peak at the same time. Not what the EGT value is. ie you want all your cylinders peaking at similar GPH values. The value of the EGT means less... Somebody can correct me if I'm wrong but i don't think there is a red line EGT.. its just that they often peak around 1450-1500ish usually. But they could be different on any plane based on probe location, age/health of cylinders etc.
The fact that you had lots of fuel on plugs 3/4 does point to your theory. Also that your EGT's seem uneven points to one or two getting more fuel or air than others.
Those are my guesses
I have never seen an issue isolated to one cylinder cause a hard starting problem.
My opinion is that now that it has that symptom, that some hyper focus on what might be going on with the engine is making the indications of a single cylinder stand out, which may be an entirely separate problem to solve.
A few years ago I suddenly started experiencing issues with hot starts. I finally found one of the intake-tube o-rings (Angle Valve engine) partially sucked out of position where the intake tube enters the sump/intake plenum. It didn't seem to cause an issue once the engine was running. I pulled the tube and replaced the o-ring and all was well after that. Another time that I experienced starting issues, I found one of the impulse coupler pawl springs dislodged/loose so it wasn't engaging the pawl.
Skylor
Considering our other team member's recent hot, (then cold also), starting issue, I'm thinking the impulse mag capacitor or some other mag issue.
So does this mean I’m an official team member now? 😎
@rvbuilder2002 you’re correct, as I said #2 EGT has always been a little hotter. But I’ve never seen it with this much spread- then again I’m hyper focused on it now. The start issue definitely got worse in the past few weeks, I flew the airplane last summer but it was a few degrees cooler as I got the plane in late August. I have a hard time believing a few degrees ambient makes this much difference.
@skylor @ZachKarpinski when I got the plane last year, I replaced 2 intake seals that were leaking in order to clean up the idle. The ferry pilot had a hard time starting the airplane at a few of the high density altitude airports he stopped at, so that was a focus when I first started flying it. The rest of the seals I replaced in April at the CI. Compressions were great at the CI, one even being 79. About 50 hours ago.
Over the winter I had a flight where the engine didn’t seem to make full power on takeoff and climb- but the plane being new to me I didn’t notice until halfway through the flight. (FP prop so the rpm varies a lot based on speed, etc.) Then there was a hiccup and the RPM picked up to normal. I assumed I swallowed a piece of lead fouling. When I landed the only thing I could find was a little blue staining on #2 injector (which is the most exposed to wind stream) the brass nut was slightly (maybe 1/8 turn) loose. After that, no more issues. So the #2 injector has been at the forefront of my conscience ever since.
I did have an A&P assist me with the CI including cleaning all fuel filters, etc.
It’s going to be a few days before I can get near the airplane with a wrench, so I’m hoping to have some more info soon. First thing, injector, if that’s clean I’ll start checking mag stuff.
The issue with this impulse was not readily obvious. About 900 hours in I started noticing the same issues you have. The tangs are riveted on with a washer as a spacer. One tang did not have the washer installed under it when the mag was manufactured. It took 900 hours and 18 years for the problem to show up. The mag had been through a previous 500hr inspection but I wasn’t having any start issues and the shop wasn’t focusing on the impulse as they were the last time.
Was able to get over to the hangar and clean#2 injector. Didn't seem overly dirty, but the passages are so small it may not be obvious. Soaked in Hoppes #9 and blew it out, used a copper brush on the air passages on the injector body (not the injector itself)
Not sure it was an issue, but it's certainly clean now.
Did 4 starts and 2 runups, it's definitely not starting as easily as it did last month but it DOES start. Also even a ground run where cylinders hit 290 isn't the same as a good heat soaking from a flight, so I'll have to wait until I can fly it to see how the hot starts go.
The #2 EGT is still hotter than the other 3, but as I said, it always has been so that "symptom" may be a red herring.
On the runups, I did cycle through each cylinder EGT and noticed a rise when going to a single mag, on either mag, each cylinder. So all plugs are firing and grounding properly.
On to some mag testing. First step is check timing with Buzz box? I did pull through and hear the snap of the impulse coupling, but as described above we don't know if that means it's really firing. Wires all look good, some insulators have chips, was planning to replace harnesses this CI.
Appreciate all of the advice so far.
Sounds like you still have the problem with the ignition. As you heard from others, a rapid change like this is something to investigate thoroughly. Any chance of swapping out the impulse mag with a loaner?
still recommend an in flight mag check at higher power. your high #2 egt still could be ignition (1 plug not firing). The energy required to spark a plug varies with what is happening in the combustion chamber and high map makes it harder (exposing a weakness not seen at lower effort conditions) and altitude also creates difficulty bridging the large gap in the cap/rotor inside the mag). Relatively common for ignition to only show weakness under heavy load. Possible this weakness is related to your starting issues as well. though could also be unrelated. certainly possible you have damage to the #2 terminal on the cap inside one of the mags. Drifting e gap can also greatly reduce energy output. Add another weakness in the #2 circuit and you only see this on one cylinder. Starting is challenging as mixture ratio is all over the map; a weak spark struggles in those situations where they don't when the mixture is where it should be.
Also, cleaning the injector is great, but you didn't look at the v slot in the spider, which can create the same symptoms.
Had limited time yesterday to play with the airplane. I did wonder about the spark under high power settings. Although the #2EGT still presents higher even at runup power settings. So I will start down the road of testing and inspecting the Mags.
Will take your advice when I get more time to mess with the airplane. I didn't take the spider or mags apart because I'm afraid of them- those are parts that could fail the engine instantly, and I would be more comfortable with my A&P over my shoulder when messing with them, at least for the first time.
A man's gotta know his limitations (y)
if you are still getting the 150* inflated egt on #2 at runup rpms and you don't lose a cylinder when dropping mags, then it probably not ignition related. but need to be sure you are carefull with the variables. Fuel is the next likely culprit, so spider examination should be on the list. Have you done a compression check? valve issues shouldn't raise egts, but you never know.
Also try leaning to see what happens to egt on 2. if it rises with all the others, it is ignition. if it starts to drop while all the others are risingh, it is probably lean and a fuel issue.
