For Sale: Subsonex (JSX-2) That was Raised by RV’s
Ironflight
VAF Moderator / Line Boy
Mentor
[Moderators – DR has approved this (highly unusual) ad]
And now for something (almost) completely different….
My little Subsonex JSX-2 is for sale. No, it’s not an RV….. but just like Mowgli in The Jungle Book, this airplane lived with RV’s its entire life, it wears the same paint job as its big, adopted sisters the “Valkyrie” and “Myst”, and it flies in the normal rotation of Valkyrie (RV-8), Mikey(RV-6) and Tsamsiyu(RV-3) – so he thinks he’s an RV as well!
VAF is for RV’s – I have always believed that. But Doug has created a huge community of people that love flying machines and he granted me permission to advertise the airplane here because, well…the Sonex forums and pages are populated by great people who think that $35K is an excessive amount to pay for an airplane – not exactly the place the potential jet drivers are going to go lurking. But VAF is a place for discerning aviators who are often looking for their next challenge and experience! If you have ever hankered for your own personal jet as your next aircraft – here it is, ready to fly.
For Sale – N958PD – “Loki”
Owner/Builder: Paul Dye
Sonex JSX-2 personal jet
Quick Build kit completed in 2019
S/N: 021
Airventure Workmanship Award: 2019
Asking Price: $145,000 (Kit/Engine/accessory cost today = $175,000)
IFR/VFR: VFR Only (limited by amps available)
Why Selling: This fun little airplane has given me a lot of enjoyment and a sense of achievement for the 220 hours I have flown it. There is no doubt that when you arrive at the fly-in breakfast as “the guy in the jet”, it gets attention. But I have lots of airplanes that need to be flown, and most of my Subsonex flights have become the same – so it is time to pass it on for someone else to enjoy (and build turbine time…). The engine just came back from its first overhaul (I have flown it twice since then to prove it out), so it is fresh and ready for years of flying.
Total Time (hrs.) on airframe: 220
First flight Date: April 2019
Original Builder (y/n)?: Yes
Empty Weight (lbs.): 487
-CG (empty): 99.159”
-date of last weighing: April 2019
Year Painted: 2019
-painted by John Stahr
Engine Make/Model: PBS TJ-100
-Total Time: 220 hours
- TTSO: 1.2 hrs.
-Engine is full FADEC and maintained per factory service manual
Flaps: electric
Landing Gear Retract: pneumatic
Elevator Trim: electric
Nav/Strobe Lights: Aveo
Recognition Lights: Aveo
Age of Tires/Tubes: Recently replaced
Avionics:
MGL EFIS
MGL Comm
Trig Transponder with ADS-B Out and In
Additional Features:
BRS all-aircraft parachute
Mountain High Built-In Oxygen
Leather heated seat
Custom Bruce’s Canopy Cover
Past Incidents/Repairs: None – No Damage History
All Airframe and Engine Service Bulletins complied with
FAA Approved Maintenance Plan
Date of Last Condition Inspection: April 2026
Maintained by: Paul F. Dye, A&P, FAA DAR
Date Aircraft Last Flown: May 2026 (Ready to fly any time)
Personal contact info:
Name: Paul F. Dye
Email: [email protected]
Phone: 713-882-8375
_RV85179 SonexJet Dye thumb.jpeg_RV86442 SonexJet Dye thumb.jpeg_RV80630 SonexJet Dye thumb.jpeg_RV80459 SonexJet Dye thumb.jpegIMG_0704.jpeg
This thing is about to make someone's dream come true.
Wish I had anywhere close to the kind of experience to take advantage of this little beast.
Good luck Paul!
How would one go about getting checked out in it?
Bob Carlton (Airshow pilot) used to be the contact for an LOA and then the Experimental Aircraft Authorization (E-AB equivalent of a Type Rating) - I’ll have to see if he is still the contact, or if someone else has set up to do it.
If it were the 2T, I'd be all over it.
Not once you research how the operational rules change when you go from one seat to two in a turbine……😉
The single seat, single engine, Experimental jet fits a - shall we say - “unique” niche in the FAA rules regarding turbine pilot currency…. to the individual owner/pilot’s advantage….
Is that why sonex had been slow rolling their two seat version?
I’d buy it in a heartbeat if I had the $$ sitting around right now! It’s probably a good thing I’m not quite old enough to pull from my 401k just yet!
  • Like
Reactions: HFS
i always wondered if airlines still count this as turbine time or dismiss it all together?
I don't know about airlines today, but when I flew they had propellers and pistons :cool: (anyone here remember the Heron?), but when I flew helicopters for a living which was a lot more enjoyable than the boring airline flights, turbine time was looked at mostly to gauge your experience during start ups and engine management, because you can destroy a turbine in seconds before it even gets to completely start if you don't know what you're doing, or if your inexperience lets your mind wander off for a second.
<< Is the engine TBO 200+/- hours? >>
Per Paul's 2024 article (referenced in #12) - "For this reason, inspections and overhauls are done on hours and/or cycles—a cycle being a start and a stop. For the PBS TJ-100, you have to have it factory inspected at 300 hours or 600 cycles (whichever comes first), then again at another 300/600. At a total of 900 hours or 1800 cycles it becomes a trophy for your mantle and you buy another one. In short, you don’t want to use up your cycles before the hours."
This is all completely true - and the reality of it is that there is one more thing - the calendar. Its 300 hours, 600 cycles, or 5 years….and the factory won;t touch it for the overhaul if you don;t observe the one that hits first. And the reality is - unless you’re making a living with it (somehow), you are never going to hit hours or cycles before you hit the calendar limitation.
Oh - someone asked me in a PM about trainign and qualifications. Bob Carlton (Desert Aerospace in Moriarty, NM and airshow performer) is still the Go To guy for training and getting the rating added to your license. Its fun, doesn’t take long….but don’t do Moriarty in August….
Ironflight,
Good of you to let one "fly the nest" if not being used enough.
Happy Landings,
Daddyman58
Noticed yesterday that they've placed sister ship (N141SX, the prototype) on display at southside admission gate.
I flew Bob Carlton's BonusJet (a two place glider converted to turbojet self launch) and was on the ground while others had their demo flights. Let's just say the noise of that engine is unmistakable.
Does she even know she's not an RV? Analogous to like my dog really just thinks he's a smaller person :)
Also, this detail is so nerdy cool :D
Oh wow I would love to have this, I had a deposit on 2 seater kit before they originally canceled it. Now I don't have the room and only 1800' strip! Wonderful and beautiful airplane, envious of whoever gets it.
