Superior Millenium Cylinder Issue and Resolution (Washboarding cylinder walls)
Shrike
I'm New Here
Posting this here because I spent some time investigating an issue and want to share the the issue and information. A little over a year ago I replaced all four cylinders with Millenium's on my RV7A with an O-360. Flew 25 hours and did an oil change and oil analysis. Oil analysis came back with elevated wear metals which is to be expected and they were not crazy high just what I would expect after a top over haul. Flew for another 50 hours and did another oil change, oil analysis and borescope. Wear metals were at about the same level as they were with the 25 hour oil change so in my mind that is half the wear metals since it is twice the flight time. The bore scope showed some odd wear on one the cylinders (See attached). I was a little concerned but thought the wait and see approach was the best course of action. Just did another 50 hour oil change, oil analysis and borescope. Bore scope showed very visible washboarding on the top of three cylinder walls running the full stroke. The oil analysis came back with increased wear metals. Compression tests were all 78/80 and the engine was running perfect with no signs of issues and no anomalous reading on the engine monitor. Oil consumption was 5 qts the first 75 hours and 3 qts the last 50 hrs so nothing excessive.
I called Superior and talked to Bill Ross. Bill told me Superior had issues with this "washboarding" off and on and chased the problem for some time before figuring out that the face of some compression rings were not correct from their supplier. Superior started shipping Millenium cylinders with Lycoming rings for a quick fix and now have a new supplier and are back to shipping cylinders with Superior rings.
The Resolution:
At no charge, Superior has shipped new cylinders, return labels to ship the old cylinders back and said they will also cover the labor for R&R. I could not be happier with the resolution to this issue. Superior stood behind their product, admitted a mistake and made it right. While I do not like my plane down for a bit over a week getting this resolved, this is the best resolution that could have come from this. A company that admits a mistake and makes it right!!! Who knew that happened anymore.
Photo 1 Borescope at 75hrs
Photos 2 Brorescope at 125hrs
Photo 3 Wear on #4 really starting to accelerate at 125hrs
If you have replacement Millenium cylinders installed within the last few years get a borescope done if you have not had one. I can't preach enough on regular oil analysis and borescopes with every oil change. I would have never know about this issue until I started using more oil and losing compression.
The Resolution:
Just went through this on a 360 i tore apart. Major pita. They offered new cylinders but would have to do all 4 as they were 10 over and lyc no longer sells 1 0 over rings and i was unwilling to use the superior rings. They did agree to nuy me conti rings and pay the shop for the honing.
I don’t have the same level of sympathy. Whilst it seems good that Superior are happy to replace faulty products, there have been so many reports of this excessive wear/washboarding on Superior cylinders that it’s beyond a joke.
To me, they are selling cheap crap and just replacing failed items instead of improving their initial quality.
Superior farm out all of their manufacturing and their quality control seems lacking. It makes a mockery of the PMA system. “Aircraft grade” - yeah right…
I bought my airplane and it has just had 4 cylinders replaced. First CI a year after and I had wash boarding on 2 cylinders. Superior replaced under warranty but didn’t cover my labor. This year I have excessive oil consumption, guess I need to borescope again and see what it looks like. Maybe I’m in the boat you are for the ring issue. 🤔 like IO390 said, I’d hate to be replacing cylinders AGAIN.
I had the same experience as Shrike with the O-360 Superior Cylinder kits. I did an OH at 1500 Hobbs because of lifter spalling and I used new Superior cylinder kits. My washboarding showed up in 5 hours using a borescope. The resolution was the same - new kits with Lycoming rings. I also dealt with Bill Ross. It is unfortunate Superior had a supplier issue but Bill was very responsive and did a good job on customer service with me. I have about 90 hrs on these cylinders now, have borescoped them 3 times, so far so good.
We found two bad sets here at 08A, on two certified airplanes with low time Superior top ends. Superior replaced both cylinder sets and and paid the labor bill. We may find more, but no one here is worried. Superior is doing the right thing.
I've had the same issue and posted on it in another thread here. No washboarding, but excessive wear and scuffing as in the OP's first picture. They replaced one cylinder at 112hrs that had compression down to 60/80, but did not replace the others. The new cylinder shows the same excessive wear. I showed them images after 25 hrs and they said they could still see crosshatching (I couldn't). I just completed a condition inspection at 160hrs. Compressions are all around 72-74/80. The metals are still elevated. Iron is coming down but chromium is still high, and I can find some ferrous metal in the oil filter. Maybe it is time to contact them again.
Seems like the wear shows up very quickly. Seems like if you make it past 10 hrs all should be good.
The Resolution:
Pulled the cylinders today. Pictures of all four. 2-4 had a lot of wear 1 had scratching/scuffing.
The Resolution:
I bought my airplane and it has just had 4 cylinders replaced. First CI a year after and I had wash boarding on 2 cylinders. Superior replaced under warranty but didn’t cover my labor. This year I have excessive oil consumption, guess I need to borescope again and see what it looks like. Maybe I’m in the boat you are for the ring issue. 🤔 like IO390 said, I’d hate to be replacing cylinders AGAIN?
How long ago did you replace the cylinders. Trying to get a timeline of when the issues was resolved?
9/25/23- 520 hours. the previous owner replaced 4 cylinders.
10/24/24- 636 hours, low compression and washboarding on #3&4. Superior replaced cylinders but did not offer to cover labor.
Today, 870 hours. noticing more oil consumption. My last borescope was in October 2025 and cylinders appeared OK.
Prob be a few weeks before I get to borescoping them again.
Pity they didn't "do the right thing" with crankshaft issues
Yep, those of us affected by that would have loved for the labour required to fix things, covered for that mess. Oh yeah, and not to have had reached into our own pockets for new crankshafts.
I still have a 50hour old Superior Crankshaft waiting for a Superior AMOC that never came…
By the way, if it really is piston rings then this has been a problem for years. I saw washboarded cylinders last year on an RV7 which had a Superior engine, that was built BY Superior about 6 years ago. It had this excessive wear pattern within the first few hours. This really is not acceptable IMO.
Back in the early 90's, GM finally decided to contract with JD Power for market data, after the 3.8L Buick LeSabre scored very high in initial quality surveys. The obvious initial question was "If our car is so good, why are customers shopping elsewhere?" The painfully obvious answer was "Because their perception of GM quality is based on their experience with their 1980's model."
I'm not a Superior fanboy. Their recent past includes more screwups than average. But hey, hang around this game long enough, and you can gin up enough history to hate everyone. Let's judge 'em on current actions.
I would suggest that the pistons and rings are the root cause. Machining a cylinder bore perfectly round is far simpler than manufacturing the complex, cam-ground shape of a piston. Furthermore, a half-keystone ring is notoriously difficult to seal when the cylinder is cold, especially given the generous piston-to-wall clearances required by our air-cooled cylinders. Finally, if the cylinder wear pattern is not strictly perpendicular to the piston pin, it points directly to a fundamental engineering or manufacturing miscalculation
I spoke to bill at length on this issue. I wasn’t buying it just happens or the crap answer the engineer gave me. It is the rings. They are being machined with incorrect angles on their faces. Not sure how the supplier got to this point, nor why superior is not cross checking in QA. Shame on them for taking so long to identify it, but good on them for supplying replacements and now supplying lyc rings.
The bottom of the ring face on a half keystone ring is machined perpendicular to the piston side wall. The taper angle on the top of the compression rings are (as I measure them = 7.5 degrees). That is the angle I have my ring lands machined to use Lycoming rings . The mating surface of the ring ( at the cylinder wall side) is convex and rides on a narrow sliver of the ring face as the piston rocks back and forth from top to bottom of the stroke. The more clearance in the ring lands, the harder it is to keep the ring stable on the cylinder wall. There is always more clearance on one side of the piston than the other as it rock back and forth in the cylinder. As the piston goes up and down, the clearance changes from sides to side with the up and down stroke of the crankshaft. If you look at a used or worn compression ring, you will probably see the wear on the taper side of the ring does not go all the way across the top of the ring from outside to inside. Obviously, the angles don't match. The half keystone ring does have a slight advantage under moderate to heavy load compared to parallel rings in slow rpm, high torque engines. (Like diesel engines)
labor? how about sending me a crankshaft and the various components that need to be replaced such as bearings and seals? I'll put it in myself
I hear you… it was not a good time. To be fair, Superior did provide a kit of the mandatory replacement seals and bolts, but that was a drop in the ocean compared to the overall cost to fix the situation.
{Personal attack deleted by mod}
That may be true, but the only explanation for the washboarding that makes any sense is bad geometry on the rings. Didn’t say he was smart; quite the opposite, as it has taken WAY too long for them to figure out the issue. Only saying that they now know the cause.
My supposition was bad rings and expected garbage responses like improper ring gaps and other nonsense. Once bill told they identified rings as the issue, i felt that they have accepted a mfg issue and know what it is.
did they? I was in contact with Bill at the time and I got nada, and no mention of any kit. They certainly didn't go out of their way to make it available. I think this topic is getting a bit thread-drifty though.
Just found this on Spruce's site. Are they trying to dump all the bad cylinders in stock? Would some unscrupulous person buy these and retag them as good?
Superior Millennium Cylinder SL36006N-A20P Complete Assembly - Damaged - Not For Aircraft Use​
0 Reviews0 Answered Questions
Now $1495.00/Each
Was $1563.00
Save 4%
Quantity
Pretty sure the washboarding stems from improperly machined rings, not the cylinders themselves.
Sorry to hear of your experience. I’m just sharing what happened for some of the customers affected in the U.K.
Well I did contact Superior and they agreed to replace all four cylinders even thought they were technically out of warranty.
They even offered to pay for shop labor, but that won't be necessary since I'm doing it myself. I'm very pleased with their support. I sent the paperwork in on Monday, received the new cylinders on Thursday and have the new cylinders mounted on the engine. I just ordered a push rod from Spruce tonight. There always seems to be one that doesn't make the right valve lash. Hopefully I will have the engine partially broken in before Oshkosh.
You shouldn’t be happy, because Superior sold you junk and that’s why it’s being replaced. You’re having to tear your engine down again because they sold faulty components for years.
I just had to deal with a similar issue with my TCM Nic3 cylinders. 8 years old and 800 hours all had excessive barrel wear. Mike Bush even wrote how great they were back in 2017.. Found out they have wear issues because the rings they specified were still to hard. Now I have Lycoming steel barrels. No more gimmick stuff for me. Also note If you pull cylinders there is a Lycoming mandatory SB and a new AD that came out this year requiring the inspection/replacement of the small connecting rod bushing. As an experimental we are not required to comply, but it is your engine.
I had to replace my cylinders twice.. Using lycoming rings did not correct the issue. The second time I sent the cylinders to a well known engine builder and they power honed the cylinders to remove some of the choke. I really think this made a huge difference. After 10 hrs no washboarding, CHT's are much lower than ever before and the engine seemed to run better on the initial breakin. This was my third breakin on this engine in 150 hrs...
CAUTION: The rocker shaft button end caps were defective in the last batch of cylinders I received. I notified Superior but never heard what they found out to be the issue. They will melt at about 250* F. They should be good to 500* +. I used some old used ones after I found melted plastic in my oil strainer. If you installed a Superior cylinder after NOV 2025 I would pull your valve covers and check the button caps.
There is a lot of choke. In some cases ring gaps exceeding new limits, but within used limits at the bottom of the barrel to achieve the correct gap at the top of the barrel.
I did reuse my old buttons except for cylinder 4 which was replaced in May of 2025 and had newer buttons. They were OK, but I opted for the latest, maybe I'll switch back.
And as such, the term “washboarding” should be replaced with the proper term….”chattering”. That’s what all the photos suggest
No disagreement, just using terms that most are familiar with. The industry seems to universally call this washboarding. Same way we call a ring gear support a flywheel.
