GAD 27 and flap switch type
Freemasm
Patron
Not sure which category this would belong to.
Background = Have a GAD 27 for flap control. Trying to order/want an Infinity stick grip.
Question = With the "bump" to next and hold for manual positioning features of the GAD 27, my perception points me to an (on) - off -(on) flap switch. Not an option on the Infinity web site.
What have other done? Phone calls to the listed number on the web site get two rings and then dead air.
Thoughts?
I know this isn't really answering your question, but have you considered not putting this on the stick grip? In my opinion, the negatives are not worth the small convenience. We put a flap paddle switch on the panel right above the throttle, which is where your other hand will be anyway.
Edit: just providing a visual of our layout. It couldn't be easier to reach this switch with a finger while my right hand is on the throttle control (which it will be every time you operate the flaps)
Thoughts?
I'm 99% sure this is the correct switch to order.
I really like my switch on the stick, very natural to operate because your hand is probably right there. (Hopefully)
If you need to call Infinity try late afternoon, Cali time.
I find the Gad 27 is an amazing tool and I very much find the mini toggle momentary tumb switch on my infinity stick grip for my flaps definitely fits the mission, my attention from down wind until I’m in the flare is outside the plane with my hand on the power control,,,, kinda handy if you need to go-around , flaps fully retract with one motion
Thoughts?
I
Thoughts?
I used a togel switch type on mine and it works great. Flap operation is easy done by feel while keeping your head up in the patern. I used a Tosten military style grip. If you order through Midwest panel they can laser label the functions. Also customer service if fantastic with Tosten.
OK, how did you label the Infinity grip so neatly? Nicely done!!
I used rub on lettering from:
If you send them a PDF of what you want, they will print an 8 1/2 by 11 sheet and send to you. Once applied spray one coat of gloss clear and then one coat of matte. 2 coats of matte was too much orange peel. I tried to laser engrave them and just burnt the plastic so no joy. I did the ones for my 14 ~4 years ago and are holding up well. (500 hrs.) If in doubt of font size just use several fonts as there is plenty of room. (14 Ariel font primarily)
Edit: I used the Infinity grips that rotate, recommended to several friends and they love them. I did this for a sailplane I use to fly years ago and liked it.
100% agree.
Question for those flying with flaps on the stick:
If you are actioning the flap with your stick thumb hand- how are you trimming coincidentally? Or are you flipping your thumb between two buttons on the stick for each stage? I can see this being either awkward (if you have position presets) or downright annoying while you put the plane out of trim with the same thumb you need to trim it.
When I’m deploying flaps with my right hand I’m simultaneously trimming with my left hand (trim on the stick). The aircraft is always perfectly in trim.
On the 7, the right hand did the throttle, the right thumb did the flaps and the left thumb retrimmed - like George’s - worked great.
It’s a very natural fluid sequence from late downwind.
On the 10 the flap switch is next to the quadrant so also easy to have one hand remain on the throttle/flaps while the stick retrims.
Richard makes good arguments. Here's some more. If you are going to put flaps on the pilot stick, will you also put it on the copilot's stick? Have you considered what would happen if a passenger bumped it at a critical moment before landing? (I can tell you that the number of times passengers have bumped the trim toggle and kicked off the AP is very much non-zero in my experience) Will you also have to add a copilot stick lockout toggle to prevent this? Have you looked at how the wires route under that stick base and thought about the failure modes there due to wear over time?
It's all a LOT of small negatives for one VERY small (IMO) positive, which is to say feeling like a HOTAS fighter jock pressing that button once or twice per flight.
Just food for thought, no choice is "bad" here.
