we did it for every device except the alternator. No high or even changed readings. Any lights and strobe were off. Main consumer is the Dynon SV with appr. 4 amps.
Bernd, Some questions & some thoughts.
#1 - What wiring arrangement is your current measuring shunt? Do you only see Alternator output (load meter function) or is your shunt in series with the battery so you can see current going into battery (a positive indication) and see current leaving the battery (a negative indication)?
#2 - Do you have a bunch of Ckt Bkrs such that you can pull them ALL thus removing power from all possible systems?
#3 - I ASSUME that you can shut off the field of the Alternator with either one side of the master switch OR a separate Alt Field switch OR a separate Alt Field Ckt Bkr ? any of these could be used to eliminate power going into the regulator portion of the Alternator (the regulator drives the field windings based on bus voltage).
#4 - Do you have a 60 amp or so Ckt Bkr directly in the Alternator Output wire such that you can isolate the Alternator output from the aircraft completely?
#5 - I ASSUME your Dynon SV screens are the only way you have of monitoring Alternator charging output... and thus using one screen on back-up is a GREAT plan, but many items are connected to that Dynon back-up battery such as ADAHRS, Knob panel, AP control panel, ARINC 429 converter to name a few including the EMS module...
If EVERYTHING except 1 screen is completely disabled by Ckt Bkrs and you still smell an odor at a high engine RPM then it could be one of these components however it's NOT likely since these are all low power draws. All this is based on my thinking you have an EXTERNAL backup battery for screens, if it's internal to the screens - different story.
My thoughts - If the Alt output INCREASES with RPMs then it's most likely the short circuit is down stream of the current shut otherwise it would not be indicated...
That said - It IS possible the Alt output voltage is going UP with RPM's, but that the voltage is being held down by the battery which is absorbing excess current without allowing bus voltage to go UP. Best way to eliminate this possibility is to measure voltage prior to the current shunt (best at Alt output terminal).
I think a reasonable troubleshooting path would be to disable EVERYTHING, using Ckt Bkrs except the 1 screen running on backup battery. This INCLUDES the Alt field & Alt Output main wire. Run the engine & see if Amps are normal or still an issue.
If Amps Ok... then Add systems one at a time to see if they cause failure mode to reappear. Possibly add back the alternator field 1st, followed by Alt main wire next, and then your choice of individual systems..
Sorry for being wordy... possibility this will help.
