For a while now I've had a sticky blue substance near my pilot side wing walk tape. At first it seemed like adhesive from new tape, and I thought of a few other things I am embarrassed to mention...So, at last today I opened things up and found where I assume it is coming from. Reference first photo here: https://www.vansaircraft.com/wp-content/uploads/2022/03/44_10.pdf
The blue stuff was exiting from under the fairing on top of the wing, near the fuel vent bend, I see no leaks.
I did see blue sticky stuff between one of the connections of the fuel supply line. Sorry, no pics and I mostly cleaned that up.
I tightened the fittings up a bit. I expect the problem is solved.
While this could get moved to maintenance issues, or something RV10 specific, what I really want is understanding! My left fuel tank has a very slow drip out the vent tube onto the ground only when tanks are full or nearly full. If the tanks are not full, no slow drip out the vent AND no apparent drip from this fitting. So why does something happen in flight? I've been told a full tank drip can be normal.
My guess and simple understanding is that the fuel pump only sucks fuel and I can't fathom why there would be any back pressure.
So, what created this condition where there can be fuel gel formation from an apparent leak, but not while at rest?
Thank you for learning me!
