Hi there.
First post here, so I’d appreciate some feedback from more experienced builders and pilots.
I’ve received an engine proposal from Continental for a Van’s RV-8 and I’m mainly planning to use the aircraft for both cruising and aerobatics. I’d be interested to hear your thoughts on this setup and whether it fits that kind of mixed flying profile.
IOX-370-CDD1U8C Fuel Injected Experimental Engine 370
370 cubic inches
C Counter weighted, Constant Speed Crankshaft
D Dynafocal Type 1 w/ roller lftrs & thrst washers
D Al Accy. hsg. with 2 direct drive mag gears
1 Parallel cylinders, AEL75089 Pistons $209.00
U Thru hardened steel barrel, tapered fins, venturi seat
8 18mm Spark Plug Hole (top/bottom)
C SAP SV78950 KIT Cold Air induction 360/370 Parallel
AF15473 AF15473 Tempest Diaphram Fuel Pump - High Pressure (FI)
EX360-2K EX360-2K Precision Silverhawk FI, O/X-370, Kit
P114-L4K-18SR P114-L4K-18SR P-Mags SR (price is for 2 ea.)
LR3D-14 LR3D-14 B & C Controller/ Regulator 14 V
BC410-H BC410-H B & C Spline drive Alternator 20A
Looking forward to your thoughts.
Regards
370 cubic inches
Regards
