I'm planning on doing the gear tower mod (screws and cover plates) mentioned in other posts ... what I have not seen mentioned is how those of you with QB fuses cut the web out with everything installed in the fuse.
I was thinking a Dremel with a cutoff wheel or perhaps a nibbler, but before I start hacking into things I thought I'd check to see if anyone had a brilliant / easy / safe way to do it.
