Garmin New G4X
Well, if a replacement for the G3X is available by this fall (and the footprint is very close to the current model), I will be unloading my two displays before ever flying with them.
Don’t hold you breath. The current universal supply chain constraints on memory and storage components do not favor new product announcements. Even folks like Apple have been pressured into pulling products off the market, or raising prices considerably, and they have the best negotiating power because they do infinitely more volume than someone like Garmin.
This!!!!! 👆👆👆👆
When flash memory has tripled or quadrupled in price in just a few months, it’s an indicator that the crap has hit the fan in the electronics supply chain.
So you all assume this is the successor to the G3X Touch? The fact that the page is still up likely means it is not what some are thinking it is.
Not saying it is or isn’t but I would be skeptical.
“The missile knows where it is, because it knows where it isn’t”…… (very obscure reference to all but the aerospace geeks…)🤣
Tom Lipton (familiar to those like me addicted to YouTube machinist videos) just featured an ‘80s era typewritten, xeroxed memo to the same effect, allegedly posted on the Veriflo Corp. shop flier, explaining how a newfangled CNC machine “knows where the cutter is because it knows where it isn’t….” Similar to the Zen of the Kalman Filter, I suspect.
Yes, they did. And it's still up. Hmm.
Looks like this Axis word has been part of a boating product.
This!!!!! 👆👆👆👆
A challenge, yes. However, I would think at the volume (small) Garmin uses (memory) within the aviation sector, it’s not in their top three concerns in getting a G3X next version out the door.
Gemini seems to think it’s already been released 🤣 but backtracked pretty quick when questioned. Must be learning from politicians.
If you post a few more topics online about the Axis, you can reinforce the gemini. Grok did the same thing, just rehashed the VAF suppositions.
Based on the features of Garmin Axis for boating, here's what Gemini thinks would translate into avonics..
If Garmin adapted the Axis philosophy for experimental aviation, it would serve as an ultra-integrated, tactical glass cockpit designed to simplify multi-system flight operations. It would merge Garmin’s commercial flight-deck power with the rapid-access, workflow-driven automation used in wake boating.
An "Axis Aviation" system would likely provide the following core features:
1. One-Touch Mission Profiles​
  • Preflight Automations: Pilots select "Takeoff," "Cross-Country Cruise," or "Tactical Descent" profiles to instantly reconfigure the aircraft.
  • Instant Adjustments: The system automatically sets fuel pump status, modifies engine cowl flaps, updates fuel tank selection reminders, and alters primary display layouts based on the phase of flight.
2. Multi-Zone Environmental & Accessory Hub​
  • Cabin Systems Control: Digitally manages interior LED lighting, cabin heating, windshield defrosting, and active noise-canceling headsets from a central interface.
  • Smart Fuse Panels: Integrates electronic circuit breakers that monitor electrical currents in real time, automatically attempting to reset tripped systems or alerting the pilot via screen diagnostics.
3. Integrated Tactile Hybrid Controls​
  • Dedicated Smart Keypad: Mimics the boat's Sport Dash with an 8-to-12 button physical keypad mounted directly near the throttle or side stick.
  • Blind-Flying Ergonomics: Allows the pilot to cycle autopilot modes, toggle landing lights, or scale map ranges using a physical rotary dial without needing to tap a touchscreen during heavy turbulence.
4. Consolidated Engine Indicating System (EIS)​
  • Real-Time Health Monitoring: Consolidates critical experimental engine data—such as individual cylinder head temperatures (CHT), exhaust gas temperatures (EGT), fuel flow, and battery bus voltages—into a clean, simplified visual layout.
  • Predictive Alerts: Highlights any out-of-bounds metrics instantly with color-coded warning banners on the primary home screen.
5. Open-Architecture Component Integration​
  • Experimental Customization: Allows builders to swap, drag, and resize digital gauges on the home screen to accommodate custom engine types, from traditional Lycomings to alternative auto-engine conversions.
  • Third-Party Compatibility: Communicates natively with non-Garmin experimental avionics, autopilot servos, and specialized wing-tip camera feeds.
6. Wireless "Pilot Band" Wearable Integration​
  • Wrist-Based Flight Tweaks: Uses a specialized Garmin smartwatch app to let a co-pilot or pilot adjust cabin audio, monitor passenger oxygen saturation levels, or look up crosswind component math directly from their wrist.
Think I will stick to my bare bone 1946 Champ.
My business specializes in high-end residential integrated systems (Control4 dealer). We typically sell touchscreen interfaces as the primary control unit for the entire home. Over the past year, the pricing of all our products with CPUs has increased. Control4 recently released their T5 series touchscreen from the T4. The T5 is currently on backorder with no solid ETA. I was told backorder was due to memory shortage.
What enhancements could Garmin make that would justify the significant increase in cost that the G4X (whatever and whenever that is, if it even is to be)? Speaking of upgrades here...I know that the tech fanz on the forum will buy it just to have it, but if all you're interested in doing is flying and navigating safely, what else could reasonably be added to the rich set of capabilities already existing. Sounds like a good way to waste money to me.
I think it goes without saying that even if they don't add specific features, there is room for a hardware upgrade. My wishlist:
  1. More screen area for the same size bezel - say 12.0" in the 10.6" format
  2. More pixels/density (like GTN 650 to 650 Xi)
  3. More screen brightness or contrast available for visibility in bright daylight
  4. Faster processor
  5. Capacitive multi touch
  6. Dedicated bezel buttons to eliminate some touch functions
This would give more room for software updates in the future even if no features were added at the initial release.
As for the cost increase, I think there is a good chance that garmin will incorporate some AI (may be rudimentary) into their systems when releasing g4x. If it were the case, release might not happen any time soon. This is purely my imagination.
Everything except #1 already exists in the "good enough" category in the G3x. No way would I pay to upgrade to any of this stuff.
#1 is pure fantasy unless you add a bunch more servos and somehow invent a reliable auto throttle mechanism.
I don’t want AI anywhere near an aircraft I’m flying.
Unless you’re thinking smart frequency selection or something basic like that.
I would pay extra/upgrade to have the G4X control the 650Xi for IFR flight.
There are potentially some intresting things AI could do like listening to ATC and automatically filling in frequency and transponder info (would have a one button push to accept). It could give you a Text readout of ATC instructions and highlight the ones that apply to you or giving a warning about an TFR and proposed route around. Also AI based voice commands so you dont have to navigate multiple levels of menu. Or an AI agent to watch for abnormalities in your gauges if you are getting short spikes in pressure or electrical usage it could bring that to your attention. You could also give it instructions like "set me up for an IFR approach to xxxx" and it would prompt you for any additional information it needed. There are quite a few things that you could use it for while restricting it so it dosent invent things.
None of these examples require the unpredictability and inconsistency of AI inference, all can be done without it. Why bring an atom bomb to a knife fight?
With all that stuff you will loose the art of actually flying, might just well go commercial
The point is that it simplifies the codeing. If you do this via older methods the coding gets very complicated quickly and have difficulty handeling input that isnt very specific. The point about AI systems is that they can take fairly vague input like human beings asking questions without all the specifics and generate an answer. Without it you have to be fairly specific and consistant in what you ask and in exactly the right format. Think the voice command systems in cars the older ones require you to ask things in exactly the format that was written by the programers.
I guess i view the art of flying to be good stick and rudder skills, enjoying the view, going places commercial aircraft dont. Anything that helps reduce the amount of time i have to spend dealing with ATC, making sure i dont miss anything from ATC, managing the nav systems and instruments etc. Just helps me have more time to enjoy the important things about flying. I guess i view that kind of thing like someone saying that I dont do real engineering because i use a computer for my calculations instead of paper and a slide rule.
My favorite flying was in my 1946 Champ off of dirt straps or fields and the best on floats with no ATC just paper maps and a compass
The computer you use doesn’t think it can do a better job than you and then try to do it without your says so though does it?
Most, if not all of the things you mention are already available without the need for AI.
I remain to be convinced that AI is going to bring anything to the party that I would actually want it to do. I certainly don’t want it anywhere near the actual flying.
It’s bad enough trying to train people who think they already know everything, never mind a computer with attitude!
My favorite flying is being able to juggle the workload of hand flying single pilot IFR in actual without missing a radio call, then breaking out a sane-but-challenging height above minimums and making a landing off an instrument approach. Most rewarding times I've ever had in a plane.
I'll never be a professional and will probably never be able to afford a lot more airplane than a piston single, so this is as close as I get to the full experience.
Fancy avionics is kind of cheating a bit but it does increase the safety factor.
There is a lot of airspace to fly in where you don't need to talk to ATC and if you aren't into VFR navigation, there is always the "direct to" button. Definitely not much to manage.
As far as your engineering statement goes, if you are asking AI for a solution to a problem instead of actually working through it then you aren't doing real engineering; the AI is. All you are doing is asking for the solution.
