bluesflyer
Member
Odd question from a non-owner RV enthusiast...
What tire size is on the RV 4, 7, and 8?
Good to know. Any issue with wheel pant fitment? Just leave them off for soft field ops, I assume?Optional larger tire 380X150, improves soft field operations.
Depends if your wheel pants are mounted high enough. You will have to widen the base area to fit what are essentially 6" tires on 5" rims. The height of the tires is also more than the 5.00x5's, but not by much. You also have to make sure you have enough clearance from your brake calipers. I operate from our grass strip 100% of the time and the wheel pants stay on all the time. These tires are noticeably better IMHO than the 5.00x5 tires on grass.Good to know. Any issue with wheel pant fitment? Just leave them off for soft field ops, I assume?
I mounted my wheel pants 1/2" higher than in the plans to create extra clearance in anticipation of installing 380x150-5.00 tires. That did create an issue with the brake calipers, so I made blister fairings on the wheel pants -- essentially a bulge to create extra room inside.Good to know. Any issue with wheel pant fitment? Just leave them off for soft field ops, I assume?
