I've used Stan's in my 29" Mtn bike tires with tubeless settups and it stops leaks quickly, with items like goatshead thorns and such. It does NOT work well in tubes at all, otherwise Stan's would sell prefilled innertubes with Stan's sealant in them.
Slime works well both in tubes and in tubeless applications. Slime does sell prefilled tubes with their sealant in it.
The problem is that it works fine from a rolling dead start going up to speed, but it will definitely create an imbalance in the tires the moment you touch down and your rotational speed of tires goes to 200 or 300 rpm or what ever the speed is when your tires touch down. It's going to be violent, with that imbalance.
Get the good Michelin tubes, is my suggestion.
