PabloSniper
Active Member
Hello, gentlemen!
I would like to point out to everyone that this topic is not intended to create a suggestion. But rather to create a brainstorm. Where perhaps, possibly, or improbably some of them may or may not be used, okay?
Well, before I present my (possibly crazy) ideas, I would like to point out that I am a fan of Rotax engines, and I believe that Van's should have other projects with Rotax, besides the RV-12, which in a way is already a reference for flight school trainers.
If this thread goes the way I want it to, we'll probably have some good ideas here (I'm not claiming that mine are)
Well, my 3 suggestions are all geared toward a twin-engine RV-10 using two Rotax 915 iS.
The first would be a sort of mini Baron.
A classic approach, with engines in the wings.
Similar to the RV-6 Twin Jag, but using lighter and stronger engines.
The second and third are more daring, with the engines aligned with the axis of the aircraft.
One has two engines in the front of the fuselage, connected to two contra-rotating propellers similar to the Macchi 72, an Italian aircraft from the 1930s, winner of the Schenneider Trophy, setting a record of over 700 kilometers per hour.
And the last one is based on the Do-335, the fastest piston fighter of WWII.
Let's awaken the creativity that exists within each one of us, and try to come up with good ideas.
I look forward to hearing your ideas.
