Davea320
Looking for ideas to thread the rod end bearing on the prop gov cable. I installed the rod end bearing on the arm of the governor since the cable bracket prevents the bolt from being removed once the bracket is installed. Now that I have the engine mounted and want to connect the control cable, I’ve been unable to attach the cable to the rod end bearing.
I’ve tried twisting the entire cable (per Vans tech support) to thread it into the bearing, but the end of the cable will not twist with the rest of the cable into the rod end bearing. Looked at possibly removing the arm on the governor, (or sliding it aft) but it has some type of locking device on the attachment bolt.
Also, the rod end bearing bolt interferes with the governor housing when trying to remove. Searched for older threads related to this prob without much luck.
Any ideas would be much appreciated as I’ve exhausted all the possibilities I can think of.
(all wits have ended)
Dave
Dave
