I missed a dimple in the bottom flange of one of the seat ribs. Skin is already dimpled. I can’t get to it to simple now. Tried using a pull river dimple set but I can’t get to it to pull it straight. What are my concerns?
I would use a rivet set with a 3/16 hole for dies. Crank down the pressure to about 10psi. Place the female die in a home made bar with a 3/16 hole. A couple taps is plenty. Home Made Bucking Bars Rivet Set with 3/16 hole
Also considered. I don’t know what I need to consider with that though. Am I creating a point for future problems? I think if i go that route, I will probably flatten the dimple in the skin as well and either use a 470 or a LP4-3
