Old 09-18-2021, 12:32 PM
msstahl's Avatar
msstahl msstahl is offline
Angry Bottom wing skin rivets
Anybody run into an clearance issue between the aileron hinge service bulletin angle and a rivet that attaches the bottom skin? Did I miss a step somewhere?
What is the best way to overcome the interference?
Click image for larger version
Name:	Aileron Service Bulletin.jpg
Omaha, Ne
RV-8 N931KZ
Empennage - Complete
Wings - Closed & Complete
Fuselage - Crating
Old 09-18-2021, 12:40 PM
N804RV's Avatar
N804RV N804RV is offline
I notched the flange of that one angle just a bit, and substituted pull rivets for the 2 trailing edge skin rivets that the SB added pieces interfere with.
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 09-18-2021, 01:04 PM
FlyGuy65 FlyGuy65 is offline
Same. Caught me by surprise on the left wing, prepared for it on the right.
Old 09-18-2021, 05:10 PM
msstahl's Avatar
Thanks for the tips, Iím sure there will be a few more surprises that catch up to me!
Omaha, Ne
RV-8 N931KZ
Fuselage - Crating
Old 09-19-2021, 08:46 AM
JDA_BTR JDA_BTR is offline
What pulled rivets did you use?
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 09-19-2021, 09:21 AM
msstahl's Avatar
Iím planning on opening the holes up slightly and using MK-319-BS rivets.
Omaha, Ne
RV-8 N931KZ
Fuselage - Crating
Old 09-19-2021, 11:27 AM
MK-319 as well. Been using that rivet as a substitute for 3/32 rivets when needed. Going to order extras with the next Vanís order.
Old 09-19-2021, 07:06 PM
dmn056 dmn056 is offline
Default Solid rivet options
It's not easy, but it is possible to do these with solid rivets.
I cut the flanges on the reinforcement angles back at 45 deg, since those bits of the flange aren't doing anything useful from a structural point of view ("adding lightness").
I was then able to just get the toe of a small bucking bar in between the angle's flange and the rivet shank. Took me a few tries, including drill-outs, but it did work ok.
If you don't want to use solid rivets, an alternative to the MK319BS is a Cherrymax CR-3214. These are a blind fastener equivalent to the NAS1097 "oops" rivets.
ID:	15988  Click image for larger version
Dan Newman
RV-8
empennage complete
wings complete
fuselage in progress
Old 09-20-2021, 05:33 PM
msstahl's Avatar
Thanks Dan, I'll give the bracket modification on my left wing a try and see where it takes me.
Omaha, Ne
RV-8 N931KZ
Fuselage - Crating
Old 09-20-2021, 06:24 PM
B6*P's Avatar
B6*P B6*P is offline
Thanks for the heads-up. I'm getting ready to install the SB and had not caught the interference yet.
RV-8 QB Kit
