Old 09-15-2021, 01:11 PM
georgemohr georgemohr is offline
Default Newbie plan question
Hi all!
On the plans for the 14, I see some references to "TYP". I understand this to mean "typical", and is used when the specifics of this feature might differ build to build.
If that is right, I don't understand the usage below. This is calling out some match drilling, which should not have variability, right? If I'm way off, please set me straight!
Regards,
G
Click image for larger version
Old 09-15-2021, 01:34 PM
iamtheari iamtheari is offline
The meaning of "typical" in this context is that they gave the instruction once and it applies typically to all of the similar places in that drawing.
Old 09-15-2021, 02:07 PM
Lovely, thanks for the clarification.
-G
Old 09-15-2021, 02:15 PM
ryane67 ryane67 is offline
So in that case it's talking about all of the rib to spar mating holes?
Ryan
RV14 tail on order, expecting to begin late 2021.
VAF donation made `21
Old 09-15-2021, 02:21 PM
I did that step 42 months ago so I don't remember for sure, but I believe it means all of those holes. The RV-14 vertical stabilizer is mostly RV-7 part numbers so there is lots of match-drilling to do. Looking ahead to page 06-05 figure 1, the rivets are AN470AD4 and LP4, so #30 holes would be appropriate.
When in doubt about what a hole is for or what to do with it, read through the rest of the section of the plans (or sometimes farther, even into other kits--this is where having the complete PDF plans at the beginning is important) to see what makes sense.
Old 09-15-2021, 03:46 PM
Yep, seems so, and that makes sense.
Old 09-15-2021, 05:59 PM
rvbuilder2002's Avatar
The provided answer is correct. It may not match the common definition for the word typical in the English language, but in the context of RV plans it is a way of describing that similar/like items on the page are dealt with the same even though the arrow is only pointing at one of them.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 09-16-2021, 06:24 AM
Thanks Scott, et al.
