Old 09-13-2021, 08:23 AM
ArVeeNiner's Avatar
Default Exhaust Leak At Slip Joint
I found an exhaust leak at the vertical slip joint of my Vetterman exhaust. As I recall, there are no seals in this area to replace, itís simply a slip joint. I donít recall seeing this before. Is this normal or is there a fix?
Click image for larger version
ID:	15764  Click image for larger version
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
Old 09-13-2021, 10:32 AM
Ralph Inkster Ralph Inkster is offline
Take that picture down to the local muffler shop, they may have a tube stretcher that could snub that up.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 09-13-2021, 11:19 AM
fixnflyguy fixnflyguy is offline
Default Pretty normal
Looks pretty normal to me. There will always be some leakage, a lttle which will close up with build-up. Mine are similar.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 09-14-2021, 12:01 AM
NDstroh NDstroh is offline
You might want to get a hold of Vetterman. I cannot tell by picture, but they have eliminated slip joint on some of their installs due to some cracking issues. I'm sure he could tell you whether the leaks you show here are cause for concern...
Old 09-14-2021, 05:46 AM
Tim Lewis Tim Lewis is offline
I believe there's supposed to be a bolt/nut holding the slip joint components together. In this picture, the bolt appears to be almost completely corroded away.
Tim Lewis
CFI, A&P
RV-10 N31TD - 1450 hrs
RV-6A N47TD - 1100 hrs (sold)
Old 09-14-2021, 06:11 AM
Walt's Avatar
Walt Walt is online now
Some units just had pins that rotated into the mating block, that is what this looks like.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 09-14-2021, 08:11 AM
ArVeeNiner's Avatar
Yep, that is correct.
So far the majority of the responses from this forum and my EAA group says it's normal but I will certainly keep an eye on it.
Thanks much!
Kelly Johnson
San Jose, CA
RV-9A
Old 09-14-2021, 11:06 AM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default Anti-seize lubricant
I use a nickel-based anti-seize lubricant at the slip joints… It will help seal.
Permatex 77124 Nickel Anti-Seize Lubricant, 8 oz
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,535 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 09-14-2021, 01:29 PM
RV6_flyer's Avatar
For past 24-years, mine have been dry. But as Stephen said, there are products available that could help seal.
I have this sitting in my hangar (I inherited it from my father) that is rated to 1,800 F. Something like this may be helpful.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-14-2021, 03:16 PM
qtrmiledan qtrmiledan is offline
Kelly- do you have mufflers? If so check to ensure the cone is not collapsed and restricting exhaust flow. I have mufflers, my slip joints donít show that leakage- 500hrs.
Danny B
Baker,La.
RV9A #91137 Flying!!
