Old 09-03-2021, 01:07 AM
TASEsq TASEsq is offline
Default Allowable flap twist
Well, my first (left) flap turned out great - as I riveted the bottom skin along the spar I checked the angles of the flap brackets as I went. They started out true and stayed that way.
However, the right flap is another story. It started out true but after the first round of rivets (every 10th one) it was about 0.2 degrees out of true. I checked after each round of rivets and it ended up 0.5 degrees out of true.
It seems an odd way of checking for no twist - I deburred the aft edges of the flap hinge brackets as a pair - did I induce a half a degree difference?
If there was a half a degree out of true on one flap - is this a lot? Iím hoping not.
Once the trailing edges are done etc I can use a laser to check them but canít think of a way at this stage that it would be helpful.
Click image for larger version
ID:	15364  Click image for larger version
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Old 09-03-2021, 04:12 AM
ShortSnorter ShortSnorter is offline
Another way to check is to mount them and ensure that the leading edge of the flap is fully against the rear spar. Then you look at the distance first row of rivets on the flap as compared to top wing skin.
Using this method - one of my flaps was off maybe 1/16" from the first rivet to the last and I have had no issues with a heavy wing.
Just read read the post - Save the above until the flaps are fully completed
Ryan
RV-14 In-Progress
Build Site
Old 09-03-2021, 04:42 AM
Ron B. Ron B. is offline
I thought the reason for checking frequently was if there was twist, one would apply a little pressure to straighten out the twist , then apply a few more rivets and check. Repeat as necessary, not continue if there is twist. If continuing was the protocol then why bother checking, just finish and wait to see the results.
I'm no expert but that is what I've been doing.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 09-03-2021, 05:04 AM
I did try and remove the twist - removed all the clecos and twisted the flap. But I could not get it to come back no matter what I tried.
___________
Trent Stewart
Old 09-03-2021, 07:26 PM
mc607 mc607 is offline
When I did mine I put a four foot level tight against the bottom skin at each end of the flap and stood back and sited the edges of the two levels. I found that to work better than the plans method of checking for twist. Late now, but I always check the spar before starting. Iíve found the spars almost always have a bit of a twist. Tuning those up before assembly is always a good idea.
Old 09-03-2021, 11:27 PM
I tried the winding stick method and by eye they look fairly twist free to me?
Bit hard to translate into a photo.
___________
Trent Stewart
Old 09-04-2021, 07:08 AM
KatanaPilot KatanaPilot is offline
Default RV-7 single data point
The RV-7A project I bought had quick build wings. The flaps had about 3 degrees of twist and Van's was fine with that.
I wasn't, so we built a new set. Spent a lot of time leveling the table, being careful during assembly and the new ones ended up at about 0.3 degrees. I thought that was nearly perfect.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2 (Honored to be Van's "Miss July" 2021)
RV-10 under construction at Synergy Air South
Old 09-06-2021, 12:37 AM
Thank you - that is good info. My TC also advised that i should ditch my digital level and build on - so will do so! Trailing edges next up.
___________
Trent Stewart
