Go Back   VAF Forums > Model Specific > RV-14
Old 08-12-2021, 12:30 PM
KatieB's Avatar
KatieB KatieB is offline
Default Finishing kit lock nuts- nyloc or metal?
Hi all. A friend of mine is building an RV-14, his 3rd or 4th RV project. He noticed that most or all of the self-locking nuts included in the kit are metal instead of the usual nyloc. Normally, one would use metal lock nuts firewall-forward to guard against heat, and nylon lock nuts firewall-aft. He's worried the metal nuts are more likely to damage the cad plating and invite corrosion on the bolts aft of the firewall, so he called Van's, but didn't get a very detailed answer as to why they ditched the nylocs. Do you all know of a good reason to use metal lock nuts on the airframe aft of the firewall?
Thanks!
Katie
Katie Bosman
EAA Homebuilt Aircraft Council
Rebuilt most of SNF tornado victim RV-3B Tony Boy II (had to sell him, but he's flying!)
RV-9 93281 tail kit has arrived... here I go again!
VAF Dues Paid 2021!
Thoughts & opinions expressed here are my own, and not those of my employer.
Old 08-12-2021, 12:46 PM
rvbuilder2002's Avatar
Two reasons
They are lighter, and cheaper.
I would think that if there was concern about what they do to the surface finish of a fastener, that they wouldn't meet stringent design requirements in place for MS hardware, but I agree, they do disturb the plating on the threads slightly.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 08-12-2021, 06:02 PM
Aluminum Aluminum is offline
Although I stuck to the plans on my -14A, I too dislike intensely the MS21042 metal replacements for AN365s for a number of reasons:
- The drag torque is much higher and more variable than nylocs, so I keep having doubts if I put enough strain on the bolt. Some folks try to measure the drag torque with a small analog torque wrench to add to set value, but I find batches to differ quite a bit in the amount of "squeeze", so I just grudgingly follow Ch.5 guidelines for nylocs figuring they aren't falling out of the sky.
- Different wrench size for bolt and nut. Need four instead of two wrenches/sockets lying around when figuring out how to access a difficult bolt.
- Most 1/4" sockets can't reach all the way down--they bottom out on the bolt so the top of the nut gets mangled, must add washers etc.
- Much more difficult to handle with gloved fingers, starting the thread blind and so on.
- Open 1/4" wrenches feel too loose on the squeezed flats, likely to strip if not careful.
- Not immediately obvious if the nut has already been used and should be thrown out (but it matters less than with nylocs I suppose).
- More expensive to replace, $0.22 vs $0.13 apiece from Spruce.
- The aforementioned corrosion doubts.
For firewall-forward stuff AN363s don't suffer from most of these issues, but they are more expensive for some reason and a bit heavier.
Dan V
'91 Zodiac 2013-2020 retired
RV-14A wiring
Old 08-12-2021, 07:26 PM
RV6_flyer's Avatar
To save weight when I built my RV-6, I replaced almost all the Nylocs with MS21042 nuts because they were lighter.
Next month with be 24-years since first flight and there are just shy of 3,500 flight hours.
I do not have any signs of corrosion that others think this substitution will cause.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-13-2021, 05:53 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
How much weight do you estimate it saved?
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 50 hours +
65 years running stock DNA
Old 08-13-2021, 06:46 AM
bjdecker's Avatar
bjdecker bjdecker is offline
IIRC the weight savings in an F1 rocket was ~4lbs. or so --- F1Boss can provide correct data.
Of note, I started down this path with my RV-7 a few years ago and ran into a couple of issues --
1. The nut isn't the same size as the bolt -- @#*&()! -- another socket/wrench combination needed for installation/removal. PITA.
2. There are differences between the MS21042s, Lubed/non-lubed. Then I looked at the data sheet for the MS21042 "L" and see that they are NOT an equivalent for the AN364/5...Oh my...
3. Then there was the hydrogen embrittlement issue from a few years back (2014)...no way to tell which ones were going to break until they broke. (https://ms21042.info/failures.html)
I decided to revert to tried/true -- AN364/365 aft of the firewall and AN363 (MS21045) ahead of the firewall..
Brian Decker
RV-7 (Flying)
Old 08-13-2021, 08:07 AM
BoydBirchler BoydBirchler is offline
I can truly say, that with 22 owned planes and over 49 years of experience: I have yet to observe any corrosion problems on bolts or machine screws caused by the use of metal locking nuts.
Old 08-13-2021, 12:29 PM
KatieB's Avatar
Thanks for the info!
If it were my plane, I'd stick with nylocs...
Katie Bosman
VAF Dues Paid 2021!
Old 08-13-2021, 12:54 PM
Toobuilder's Avatar
Just about every nylock nut I see in my shop automatically goes in the trash whether new or not. I use the MS21042's on almost everything.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
