Old 08-10-2021, 03:23 PM
RV-Ogler RV-Ogler is offline
Default Edge distance questions
I buggered up a hole drilling out a rivet on my RV14 rudder and had to up size the No 4 rivet to a No 5. Waiting to hear what Vans says about it, part R-606PP. Is the distance measurement 2X diameter from the center of the hole?
Click image for larger version
Old 08-10-2021, 04:39 PM
Norman CYYJ Norman CYYJ is offline
From the center of the rivet being installed.
Old 08-10-2021, 04:41 PM
Girraf Girraf is offline
Yes, Edge Distance is measured from the center of a hole to the material edge.
That hole doesn't look bad to me but I'm not sure if that pre or post upsizing to #5 rivet hole.
Vintage Cherokee 160
RV-7:
Empennage complete
SB Wings to QB stage
Fuselage in progress
Finish kit/Engine/Prop Ordered
Old 08-10-2021, 04:44 PM
wirejock's Avatar
wirejock wirejock is offline
Depends a little on material but typically 2D from center of hole to any edge. I do suggest practicing on drilling rivets. Ask if you need some best practice advise.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 08-10-2021, 05:01 PM
The picture is from after upsizing from a 4 to a 5.
Old 08-10-2021, 06:58 PM
Desert Rat Desert Rat is offline
Rule of thumb is 2d from center of the hole, or 1.5 d from the edge of the hole, but if you look at the mil spec its actually a little bit less than that.
Vans has a link to the appropriate mil-spec on their web site under the builder support tech Q&A section.
https://www.vansaircraft.com/faq/mil...n-and-install/
The min mil-spec edge distance for a -5 non flush rivet is .281"
It's important to understand that a mil-spec is generic approved engineering data that can typically be defaulted to in the absence of other approval, but if manufacturing prints say something else, then that would take precedence.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 08-10-2021, 09:24 PM
blaplante blaplante is offline
Default Another Option
Instead of going from #4 to #5 another option is CherryMax oversized rivets for a slightly messed up hole (per the link typical oversize is .01"
So a #4 would be 0.125, the Cherrymax oversize would be 0.135,
while a #5 would be 0.156"
So it would certainly lessen edge distance concerns.
https://aircraft-tool.com/shop/detai...ookieSupport=1
Obviously you'd want Van's opinion on using the CherryMax instead of a solid rivet.
RV6A in phase 2 as of April 2016
Donation made Oct 2020
Old 08-11-2021, 08:58 AM
Showed the pic to mothership, was told to build on. I do have a Vans practice control surface kit in my shop Iím gonna work on that first.
Old 08-12-2021, 07:05 AM
JeremyL JeremyL is offline
Yeah, looks fine, build on.
_____________________________________________
RV7A(in construction)
https://eaabuilderslog.org/?s=N524JL
Old 08-12-2021, 07:52 AM
acam37's Avatar
acam37 acam37 is offline
When in doubt, ask the people at Vans. You should see the stuff I deal with on store bought planes. You would be appalled at what quality control lets go the door. Some of the worst riveting Iíve ever seen is on Cessnas.
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
