Old 08-03-2021, 05:02 PM
RV-Ogler RV-Ogler is offline
Default Vintage Mooney Owner now also RV-14A Builder
As if I didnít have enough work to do caring for a vintage Mooney. I was presented with an opportunity/bargain to good to pass up on an essentially untouched RV-14A tail kit plus what seems like almost all the tools in Cleavelandís catalog and a couple months prepaid for the hangar/workshop itís in. A guy at my field decided building was not for him and would rather spend his resources flying. Wife said go for it.
I hope to fly the Mooney while I spend the next several years (5 to 10 I think) building the RV. Feels like I may have jumped in the ocean with no swimming lessons.
I have 2 questions. This tail kit is still at a very early stage. So what would it take to convert it to a 14 instead of a 14A?
Also what info does Vans need from me as far as taking over someone elseís project?
Thx,
Seth
Old 08-03-2021, 05:04 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF
Seth, welcome to VAF
The tail kit most likely will work with either the straight 14, or the a.
Best is to contact the factory.
As far as the transfer, you just need to let them know you have the plans number and they will take care of it. I took on a partial built RV 10, and there was no issue with the transfer.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 08-03-2021, 07:33 PM
StressedOut StressedOut is offline
The main difference is, well, in the tail.
There are some different parts supplied in the kit for the tail dragger. The tail wheel spring mount (P/N U-00018) is the most obvious one. Also, on the F-01479 aft bottom skin you'll need to remove a decent sized chunk of the skin to make room for the tail wheel.
Some of the operations are slightly different for nose and tail wheel models. They're grouped together and clearly spelled out in the plans.
I think from a parts standpoint the tail wheel spring mount is one you'll have to order. I know it didn't come in my kit. There may be more, so I recommend a through reading of the plans to identify them.
Art Jackson
RV-14A Kit#140433
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator, Rudder #2, Aft Fuselage)
Ordered: Wing Kit (Arrives March 2021)
Construction log - mykitlog.com/ajackson
Dues paid on March 2021
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
Old 08-05-2021, 12:30 PM
SantosDumont SantosDumont is offline
The tail kit is basically the same for both planes. If you haven't yet, it's worth buying the digital plans. They sell them on USB for $10. I took Adobe acrobat and combined all the sections into one PDF that I carry with me on my phone. (I don't know why Vans doesn't just distribute this as one PDF)
The 14 and 14A are the exact same set of plans. The page you are looking for is 10-16 which explains how you will modify the empennage for the tail gear.
You will realize this as you start building, but unless you live in your hangar, you will want to move the build closer to home so when you have a free 2 hours you can knock out some rivets. If you only build in the hangar you will add so much time to the build with just travel to the hangar.
Also if you are on Facebook there's a RV-14 group on there as well, although this forum is usually the best place to find RV information.
Old 08-06-2021, 08:49 PM
esco esco is offline
Default 14A to 14 conversion
Seth:
I intended to do the same thing, and bought the initial "extra" parts needed to change the tailkit.
Since I didn't install them, I'd be happy to see them put to use.
Send a PM and we can chat offline.
______
VAF dues paid though exempt
RV-9A sold (I miss that bird!)
RV10 sold (miss that one too!)
RV-14A build underway
Old 08-07-2021, 07:54 PM
kiljoy's Avatar
kiljoy kiljoy is offline
Congrats Seth. It's a really fun trip.
My only advice is practice riveting. I wish I could go back and start over with the tail again (because I was horrible then and the amount of bondo I'm going to need to use to cover up the smilies is embarrassing).
Dues paid (2020)
RV-14 #140394
Empennage - done(ish)
Wings - done(ish)
Fuselage - done(ish)
Finishing Kit - Somewhere in there
YouTube Build Channel
Old 08-07-2021, 08:28 PM
Toobuilder's Avatar
How "vintage" is your Mooney? (Former 1958 M-20A woodwing owner)
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 08-10-2021, 08:27 AM
hoppytodd hoppytodd is offline
Default Welcome!
As if I didn’t have enough work to do caring for a vintage Mooney. I was presented with an opportunity/bargain to good to pass up on an essentially untouched RV-14A tail kit plus what seems like almost all the tools in Cleaveland’s catalog and a couple months prepaid for the hangar/workshop it’s in. A guy at my field decided building was not for him and would rather spend his resources flying. Wife said go for it.
Also what info does Vans need from me as far as taking over someone else’s project?
Thx,
Seth
Seth,
You are not alone. I currently own a 1980 M20J and I am building a "slow build" RV-10 to replace it at sometime in the future. The 14 is a great airplane and I watched one at Synergy Air South in construction when I was there a few months ago building my empennage. Good luck with you build and welcome aboard. If you made it to AirVenture this year FlightChops had their RV-14 on display behind the Garmin tent. It was a very nice plane.
Todd
Former Pro Pilot now having Fun
Building a RV-10
Currently flying a M20J
VAF donation current for 2021
Old 08-10-2021, 09:12 AM
coffeeguy coffeeguy is offline
Andrew,
Same here, although I think we are in the majority of first time builders. I joked that I was going to put the titleist logo on the vertical stab. Of course any mistakes seems 10x worse at the time. How many people think that they are now qualified to build an airplane after they build an airplane?
Jeff
Jeff Dingbaum
RV-14A empennage, wings, fuselage, finish
Cherokee 180
Old 08-22-2021, 05:31 PM
Thanks Iíve put together 3 practice control surface kits now. Iím tempted to drill them apart and put them back together.
