Old 07-18-2021, 08:11 PM
jwyatt jwyatt is offline
Default Removing stuck lord mounts
With my engine removed for repair, I’m attending to various FWF tasks while I await its return. I’d like to measure the rubber mounts to see if they are within spec, as the lower forward isolators appear to be “eccentric” as Lord calls it. But, the fore and aft pieces are stuck firm in the dynafocal rings. Some light prying and tapping with a hammer and wooden drift produced no results.
How does one remove the isolators? BFH? The aft side of he uppers came right out but the lowers aren’t moving.
Related…best to replace the lower mounts, or shim them, to correct for the sag that’s occurred over the last 550 hours?
Joshua Wyatt | Goodhue, Minn.
RV-9A N627DW @ KRGK - Flying since 2012
AFS 4500s | Stratux | SDS EM-5
rv9a.pacificrimsound.com
Old 07-18-2021, 08:33 PM
Saber25's Avatar
Saber25 Saber25 is offline
With that many hours and what you describe on how they look, this would be a great time to replace.
Build 'em light, keep it simple
I'd rather fly than tinker.
"There's a big difference between a pilot and an aviator. One is a technician, the other is an artist in love with flight."
- Elrey B. Jeppesen,
Old 07-18-2021, 11:25 PM
gasman gasman is offline
If your mounts were new 550 hours ago, they should be good to 2000 hours.
Maybe post some pictures.
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Old 07-20-2021, 04:28 PM
You can see there’s some sag going on under no load. The condition of the rubber parts looks good, just a bit droopy. I’d say there was settling on the spinner in the first 150 hours but it’s been in the same spot since then.
Click image for larger version
ID:	13857  Click image for larger version
Old 07-20-2021, 07:06 PM
BoydBirchler BoydBirchler is offline
I would shim them. I have had to shim nearly every new set I have put on in order to get the cowl to match the spinner. I have seen no down side to doing so, and would do the same with your fresh looking 500 hour mounts.
I have seen many RV mounts installed backwards. When installed correctly the one on the top in front, is on the back on the bottom. One mount in the set is harder duromitor (harder rubber) than the opposing in it's set. The rubber mount getting compressed needs to be the harder of the 2 mounts. The mount under compression on the top ears is on the opposite side on the bottom ears.
Old 07-21-2021, 06:43 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
I need to shim mine a bit after 50 hours... is it acceptable to insert a U- or perhaps better described as a C-shaped shim, or is it necessary to pull the bolt to insert a full-circle shim? I don't relish removing and realigning those bolts although I've done it before to hang the engine.
I can't easily envision cheater C-shim coming out but they'd alter the bolt torque if they managed to work out from under.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 50 hours +
65 years running stock DNA
Old 07-21-2021, 06:44 AM
PDC RV8's Avatar
PDC RV8 PDC RV8 is offline
The rubber mounts appear to be installed correctly. The ribbed rubber portion should be under compression.
View - https://youtu.be/jcM2x_g7wf4
Phenom 300 Captain
RV6 or 7 next
Last edited by PDC RV8 : 07-21-2021 at 06:56 AM. Reason: corrected wording from incorrectly to correctly
