Old 05-25-2021, 05:39 PM
Vfr1200's Avatar
Vfr1200 Vfr1200 is offline
Default Recommendations on spray gun
So Iím on my second spray gun ,, been buying cheap tools up to this point
Iím sure its my inexperience on cleaning a gun but ive tried different ways with same results ..
Iím using the Stewart Eko prime and i get about 3 good priming sessions out of the gun and it quits spraying ,,
Today it sprayed perfect for one aileron and went to do the second and it clogged up again ,,i cleaned the gun with thinner sprayed some thinner through the gun and it was spraying fine , fill it back up with primer and no bueno was instantly clogged
Any advise would be greatly appreciated
Iím using a spray gun from manards but ready to try a something else at this point
Old 05-25-2021, 05:51 PM
jibby212 jibby212 is offline
Are you using a paint strainer, maybe it contaminants in the paint.
Old 05-25-2021, 07:15 PM
Vansconvert Vansconvert is offline
You ne if you were not already doing so, need to unscrew the cap and take the nozzle out that the cap holds on and clean it very thoroughly. DeVilbiss finish line 4 is a quality gun for under a couple hundred bucks. Paint is very expensive. And the effort it takes to reprep a surface is frustrating to say the least. I would spend the money and get a quality gun.
RV-7A
IO-360 Hartzell CSP
Purchased
Old 05-25-2021, 07:24 PM
wirejock's Avatar
wirejock wirejock is offline
Default Cleaning
What he ^ said.
Disassemble and thoroughly clean the gun every session. Stuff builds up in the tip real fast. I neglected itba session or two and removed a big doughnut shaped wad 1/8" thick. It should be nice and shiny inside. Check the needle. Check the nozzle too. Lots of tiny holes to direct the fan. They all need to be clear or the fan will spray crooked.
I really like my DeVilbiss FLG, but today I bought a Harbor Fright Black Widow HTE. Dang thing is a work of art. Can't wait to try it. It's a copy of the SATA 5000 ($999) gun.
By the way, they are on sale till end of the week.
https://www.harborfreight.com/20-oz-...gun-56153.html
3M PPS cups have a built in strainer. I use 6oz 200 micron.
Last, use a quality regulator at the gun. Inuse an RTI Mini 1/4". Hose from compressor feediing the air/oil separator then regulator at the gun.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 05-25-2021, 08:33 PM
gyoung's Avatar
gyoung gyoung is offline
I recently upgraded to the Devilbiss Finish Line 4 from their Starting Line gun when my skill level finally outgrew the SLG. The FLG4 is awesome, much better pattern than the SLG. They all demand proper cleaning. Pull the needle and nozzle. I use the Dekups system, disposable measuring cups and a squeeze bottle with MEK. The combo makes cleanup a breeze and minimal solvent needed.
Greg
1950 Navion - flying
RV-6 - first flight 5/6/2021
1940 Rearwin Cloudster project in progress
4 L-2 projects on deck
Old 05-25-2021, 08:52 PM
Bandera Bandera is offline
Paint strainers can be had pretty cheap on Amazon. Itís always good to use one, especially for primer. The solids in primer are not ground as fine as paint. A good clean after you spray also goes a long way. I like to pour a little thinner in a mixing cup and put the air cap in it while I clean the rest of the gun. When thatís done Iíll give the air cap a good brushing and then wipe it down with a clean paper towel.
A good inexpensive paint gun that I like is the Devilbiss FLG5. Itís about $140 from spraygunsdirect. For an extra hundred you can get a Devilbiss GPi. Itís a pro level gun at a reasonable price.
Vfr1200's Avatar
Default Gun cleaning
Great tips and great advise , pretty sure it has to be in my cleaning stage ,, Iíll disassemble the gun tomorrow to clean internal parks ,, down side of the situation is Iím about out of primer and my order is on back order like everything else these days , I did purchase to the ratttle can for a back up but prefer not to mix match primer colors
Old 05-26-2021, 05:19 AM
Vfr1200's Avatar
Default Prime
When the gun works i gets good results
Click image for larger version
Old 05-26-2021, 05:53 AM
rvanstory's Avatar
rvanstory rvanstory is offline
Default 3M Accuspray
I used a 3M Accuspray for my primer. If gun is clogging, perhaps you can switch to larger sized spray tip (comes with 1.2mm - 1.8mm tips). Clean up is the easiest of any sprayer I've ever used. You can throw tip away (disposable) or, clean and reuse. Thorough cleaning after use takes about 3 minutes (at most).
https://www.amazon.com/3M-26580-Accu...2029515&sr=8-6
Randy Vanstory
Flying RV10 - N783V
2021 Sun N Fun Reserve Grand Champion
2021 Oshkosh Bronze Lindy
1st Flight 08/20/2020
Donation Happily Made 2021
Old 05-26-2021, 06:26 AM
Moresushi Moresushi is offline
Default Cheap HVLP Spray Gun
I've had good luck with the inexpensive purple HF HVLP Spray Gun. Cleaning prior to first use and after each use is important. The tip is VERY hard to remove the first time. There are some good videos on YouTube on cleaning, setup and use. Good Luck!
Bill
Spring, TX
EAA Chapter 302 Member
KCXO Conroe, Texas
RV-10: Under Construction
https://eaabuilderslog.org/?s=wcooper
