Old 05-24-2021, 07:33 AM
bob865 bob865 is offline
Default R-716 Fairing Attachment at the bottom of the rudder.
Made my first glaring mistake on the plane that I'm not sure how to fix. I'm working on the rudder and has to fabricate the R-716 rudder bottom attach strips. Well I measured wrong and they are about two inches too short. The problem is I don't have enough material left to fabricate new ones of the right length. I know I can order more, but looking at what these attach strips do, I think I can make it work. I cut the fabricated ones so that the end fell between two rivets and cut an additional piece to fill in the difference. Pics are attached. I need to deburr and clean it up, but the idea is circled in the pic.
Asking the more experienced Vans community....Do you agree with my assessment?
Click image for larger version
ID:	11899  Click image for larger version
--Adam
First Time Builder
RV8A- Status:
Empennage Kit: In work (85%-ish)
Wings Kit: Ordered (Standard Build)
https://eaabuilderslog.org/?s=Adam_RV-8
Old 05-24-2021, 02:20 PM
Jonnyb's Avatar
Jonnyb Jonnyb is offline
Given how early you are in the build, and how easy and cheap the part is to replace, why even bother trying to fix it? Order some more Aluminium, and add that stuff to your pile of scrap material for later use.
You could probably make some more from the trim bundle that’s included with the empennage kit. I’m not sure if it’s long enough, but it’s worth checking.
RV-8
Empennage done
Wings in progress
Old 05-24-2021, 05:41 PM
Girraf Girraf is offline
Sure it may be a little early in the build to be satisfied with a minor mistake like that, but given that its job is to hold a fairing, I think your solution is fine. You could even take another step and make a doubler to span across the gap and tie the two pieces together but that's probably overkill.
Vintage Cherokee 160
RV-7:
Empennage complete
SB Wings to QB stage
Fuselage in progress
Finish kit/Engine/Prop Ordered
Old 05-24-2021, 06:03 PM
wirejock's Avatar
wirejock wirejock is offline
Default Scrap parts
I think it would probably be fine too, but why not borrow some scrap from a local builder and re-doo?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 05-24-2021, 08:17 PM
pilotkms's Avatar
pilotkms pilotkms is offline
Do what Johnyb says. You’re gonna make a lot more mistakes. Get ready for them.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
750+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
Old 05-24-2021, 08:58 PM
ScottK ScottK is offline
Based on messing up the same parts on my rudder, and for the job they do, I think you'd be fine with your patch. But I am not an engineer. I also think I didn't want to set the tone for my build that way, and spent less than $10 for new metal to remake them correctly (spoiler, I have a local supply house).
Scott K
KU42 / RV-9A [Wings]
Old 05-24-2021, 09:07 PM
Mikeyb Mikeyb is offline
I looked at your kit log. You are moving right along. These are the type of “what’s good enough” questions you are going to have to make all the time.
Good luck!
Mike
Old 05-25-2021, 10:26 AM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
Van's support is usually pretty quick on answering questions like this.
support@vansaircraft.com
Don't be shy. :-)
Pete
RV14A Tail kit 95%
Wing kit 95%
Fuselage QB stuck in China virus corrosion purgatory
RV 14 WIKI in Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
please purchase the thumb drive Vans offers. I DO NOT want to take away from sales flow or get the WIKI Killed.
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 18,19,20,21 Military exempt
Old 05-25-2021, 03:30 PM
PhatRV PhatRV is offline
I found that I had to purchase extra aluminum sheets in 0.032" and 0.025" from Aircraft Spruce to fix mistakes like this. They also come handy at the later stage of your build when you need to build parts that are different than in the plan, such as avionic shelf.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Done. Fiberglass 80%
Avionics Installation -- 90%
Firewall Forward -- Cowl completed. Baffle 90%
Electrical -- 90%
Donation paid through 2021
Old 05-25-2021, 04:39 PM
Ralph Inkster Ralph Inkster is offline
I suggest you leave it as is for now and continue on. Order in a bit of .025 & .032 sheet as is always nice to a bit extra. Come back to it & the fairing later when you have decided what type of tail lamp you will be mounting in the fairing, as you will find that you have to trim the rear end of those strips to make room for the tail lamp/strobe housing.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
