Old 05-23-2021, 01:52 PM
Lt Dan Lt Dan is offline
Default Rear Seat Lap Belt Bracket Corrosion
I decided to remove my rear seat belts for thorough cleaning after an unfortunate barfing incident while giving a Young Eagles ride...
When I removed the lap belt from the side attach points I discovered surface rust on the brackets as depicted in the attached pictures. I removed the brackets and plan to take a wire wheel to them, then prime and paint them to prevent further rust. I have a few questions I wanted to run by the forum, as I am handy, but not a builder, nor A&P, and these are what I would deem safety-critical pieces of hardware.
1) Is removing the surface rust with a wire wheel, painting, re-installing, and putting back into service a perfectly safe and acceptable practice?
2) What would cause rust like this? There isn't a speck of rust anywhere else on the airplane. Could it be a case of incompatible metals?
3) Shouldn't this kind of thing be caught at every Condition Inspection? Maybe it was observed last time but I'm over reacting...?
I have Hooker Harnesses if it makes any difference.
Thanks for the insight!
Dan
Click image for larger version
Name:	Seat Belt Bracket - 1.jpeg
08 RV-4
09 RV-8
Old 05-23-2021, 02:18 PM
Ironflight's Avatar
VAF Moderator / Line Boy
1) yup - wire wheel, prime, paint as desired - that’s just surface stuff.
2) I’m guessing they were installed as bare metal, and got some moisture on them. Even painted, they are going to get scratched and expose bare metal which can rust.
3) Sure, it should be caught, but also it isn’t very significant at the point you caught it, so clean, prime, paint and look for it next time.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-23-2021, 06:02 PM
wcalvert's Avatar
wcalvert wcalvert is offline
By the looks of the photo those were never painted or treated at all. That bright orange rust is a giveaway.
I've had great success on steel with Rustoleum Self Etching primer... holds up well with a thin coat that won't chip off as easily as some.
Brush, clean with solvent, prime and then paint.
Build on!
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
First Flight 7/17/2021!!
- Been there, Donated 2021
Old 05-23-2021, 07:34 PM
rv6n6r's Avatar
rv6n6r rv6n6r is offline
In my experience, any bare steel is going to rust. And still may eventually show some spots if primed / painted.
Then again I live in the Pacific North-Wet
As for what to do: +1 on the previous responses.
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Donated August 2021
Old 05-23-2021, 08:33 PM
This is awesome. Thank you guys!
08 RV-4
09 RV-8
