Old 04-25-2021, 05:01 PM
JDA_BTR JDA_BTR is offline
Default Landing Gear Puzzle - RV-8
RV-8 slow build. Lining up to drill the gear holes. I can't sweep the legs aft enough to make the leading edges inboard and outboard all line up on the same plane while being able to maintain proper edge distance on the outboard load plate and also at the limit of the aft bolt hitting the fairing z-channel even after relieving a fair amount of the corner.
My best compromise is to sweep aft best I can, ensuring the 3/16" edge distance is on the money laterally, and accept that the legs arent truly square across the entire leading edge.
Doing that, ensuring that the gear distance to tail is same both sides, and distance to a straightedge forward is same as well, I feel pretty confident the axles are going to be very close in position fore and aft.
The other reason I would like to sweep the legs more is for the slight toe-in condition that exists where the legs end up. See in the pics I clamped straight edges to the foot of the leg to measure the toein. A foot aft of the axle the straightedge shows about 5/8" wider a foot behind the axle than at the axle (the two legs are toed-in 2.5-3 degrees). Not sure which is more or less because I don't have the true centerline to measure to up there. I presume I can fix this with shims. I think it will change a bit once the bolts are in and down too.
Am I making the right compromise or am I missing something in my setup?
Click image for larger version
ID:	10830  Click image for larger version
ID:	10831  Click image for larger version
ID:	10832  Click image for larger version
ID:	10833  Click image for larger version
ID:	10835  Click image for larger version
ID:	10836  Click image for larger version
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 04-25-2021, 05:10 PM
D Weisgerber's Avatar
D Weisgerber D Weisgerber is offline
I had the same problem as you, I swept them back as far as I could and still kept the edge distance I needed. I just finished my alignment, I had to install a couple of shims to take out the toe in.
Dave Weisgerber
RV8 N848DW. Ser#83830 done.
James Cowl
DAR inspection on 7-23-2021
First flight on 7-25-2021
Phase 2 on 9-3-2021
Old 05-03-2021, 07:56 PM
vomatic vomatic is offline
JDA-
Did you get it figured out? Have you drilled your holes yet? I spent the weekend doing mine and just got it figured out tonight. I was off by almost 2" at the tail bulkhead when I started. Happy to share pictures if it would help. I'm sleeping on it before I drill just to make sure I'm not missing something.
David
RV-8 QB
Tail - Done
Fuselage - In Process
Old 05-03-2021, 08:27 PM
I have mine all drilled now. What I had to accept was that the gear legs are not true across the front top and bottom and will have some camber. But the bolts are all in the right place and the gear legs are both same distance to the tail and true in that respect. I think Iíll be using some shims to have the axles true athwartships later.
N804RV's Avatar
N804RV N804RV is offline
I was frustrated with lining up the plumb bobs. I went and bought 2 4' carpenter's levels from Harbor Freight and clamped them to the outboard face of the each gear leg with them exaclty on center. With the fuselage leveled and the levels on the gear legs centered and leveled, I measured the distance between the forward and aft ends of the levels. Once I got the distances equal, I dropped a plumb bob off the most outboard point of the leading edge of each gear leg and marked the point on the floor under each gear leg. I also dropped a plumb bob off the tooling hole of the F-812 buckhead and marked its corresponding point on the floor. Then measured from the marked points on the floor from each gear leg to the point marked for F-812. Once I got those three measurements in agreement, I then double checked my dimensions for the outboard wear-plate/bracket set on each leg.
I ended up trimming quite a bit off the Z brackets, so much so that I changed from a double lug nutplate to a single lug nut plate on the aft Z bracket. But, all the numbers worked out to perfection. And, when I went back and dropped the 2nd pair of plumb bobs on the inboard leading edges of the gear legs (per Van's) low and behold, they all lined up, perfectly!
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 05-03-2021, 08:31 PM
My problem with doing what you described is that the wear plate would end up cockeyed and not have correct edge distances. So I compromised to keep edge distances right knowing I could shim later. But I did make dead sure the legs were swept back as much as I could reasonably do with both legs equidistant from the tail. I also measured them equidistant from the firewall transverse line. Right and left arenít perfect but they are equal. Close enough to let shims fix the small difference.
Old 05-03-2021, 08:51 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is online now
If you decide to install the stronger gear bolts, let me know. I have a set for both sides plus the wedges so the bolts don't turn and you can check tightness later from the bottom without needing to hold the top of the bolt.
Sadly sold my RV-8 however still trying to enjoy life by developing an airport with FREE campsites for pilots to enjoy www.facebook.com/VacaMooAirport/ & flying a C-177 while waiting for the RV15 !
Exempt by 3 out of the 10 ways but I still donated.
Old 05-03-2021, 10:28 PM
N804RV's Avatar
My problem with doing what you described is that the wear plate would end up cockeyed and not have correct edge distances....
Huh! I didn't have that problem. My wear plates and brackets were proper dimensions. And, the final holes were right where they are supposed to be.
I do have the SkyDesigns Aluminum landing gear. But I can't see how that would've made a difference.
Glad you found a solution! :-)
My problem area seems to be mounting the flap control tube blocks right now. So, I guess that's payback for having an easy time with the gear.
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 05-04-2021, 07:57 AM
I have the bolts and clips to put in thanks. The aluminum gear legs are quite different so no surprise they are easier to line up. I have the stock steel gear.
Old 05-19-2021, 03:28 PM
benjam benjam is offline
Hi Ken.
I too am fitting the sky design gear right now to my QB RV8. Do you have any piccies of the process? I am trying to sort out the instructions for the VANS gear legs verses the skydesign gear, and am not really sure about the plumb bob and alignment setup.
Cheers, Ben
Trying to keep the QB fuse build progressing...
